Home » Eclipse Projects » Babel » No translations for Subversive
Re: No translations for Subversive [message #25544 is a reply to message #25424] |
Sat, 14 March 2009 06:37 |
Originally posted by: atoulme.intalio.com
There are currently no entries for Subversive. Please check your map
file is correct.
Igor Burilo wrote:
> Can anybody from Babel Team answer it?
>> Hello,
>> I wanted to run Babel Pseudo Translation Test to verify Subversive
>> translatablity (following to guidelines from Galileo Simultaneous release)
>> I just checked Babel Language Packs from nightly builds:
>> http://build.eclipse.org/technology/babel/test-updates/ganym ede and didn't
>> find any translations for Subversive project. (I checked nightly update
>> site because Babel Language Pack Update Site for Ganymede doesn't work, as
>> was already noted here in newsgroup).
>> Then I checked Subversive at translate
>> page(http://babel.eclipse.org/babel/translate.php) and Subversive project
>> is present there but there are no translations for it, despite that when I
>> was adding Subversive to Babel I definetely saw translations for it. (I
>> also provided our legacy translations for Subversive to Babel)
>> What could be the reason that there are no translations for Subversive,
>> maybe I missed smth.?
Re: No translations for Subversive [message #25656 is a reply to message #25544] |
Mon, 16 March 2009 08:43 |
Igor Burilo Messages: 435 Registered: July 2009 |
Hello Antoine,
I see a post from Elena Nayashkova and it seems she has the same problem. So
I removed the second trunk definition, e.g. presviously I had entry:
plugin@org.eclipse.team.svn.core= SVN,trunk,http://dev.eclipse.org/svnroot/technology/org.ecli pse.subversive,,trunk/org.eclipse.team.svn.core
but now I changed it to:
plugin@org.eclipse.team.svn.core= SVN,trunk,http://dev.eclipse.org/svnroot/technology/org.ecli pse.subversive,,org.eclipse.team.svn.core
I hope it helps.
> There are currently no entries for Subversive. Please check your map file
> is correct.
Re: No translations for Subversive [message #25685 is a reply to message #25656] |
Tue, 17 March 2009 08:36 |
It still doesn't work, so I fired a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268926
> Hello Antoine,
> So I removed the second trunk definition, e.g. presviously I had entry:
> I hope it helps.
>> is correct.
Re: No translations for Subversive [message #25829 is a reply to message #25685] |
Tue, 17 March 2009 11:44 |
I replied there. Thanks for opening the bug.
Igor Burilo wrote:
> Hello,
>> Hello Antoine,
>> I hope it helps.
>>> is correct.
Re: No translations for Subversive [message #577337 is a reply to message #25424] |
file is correct.
>> Hello,
Re: No translations for Subversive [message #577402 is a reply to message #25544] |
Hello Antoine,
I hope it helps.
> is correct.
Re: No translations for Subversive [message #577420 is a reply to message #25656] |
> Hello Antoine,
> I hope it helps.
>> is correct.
Re: No translations for Subversive [message #577446 is a reply to message #25685] |
Igor Burilo wrote:
> Hello,
>> Hello Antoine,
>> I hope it helps.
>>> is correct.
Current Time: Thu Apr 25 10:19:17 GMT 2024
Powered by FUDForum. Page generated in 0.04041 seconds
