Tooltip not available for custom widget [message #1434602] |
Tue, 30 September 2014 10:14 |
Alexandru LATA Messages: 8 Registered: October 2013 |
Hi all,
After, finally, managed to create a custom widget for fusioncharts library using the Remote-API I'm facing with the following problem: the chart's tooltips are not displayed.
I am assuming that this is caused by chart's tooltip z-index (99999) value. Knowing that, if I'm changing z-index value to 10000001, for example, the tooltip appears.
I should mention that I've already tried, without any success:
- the moveAbove method;
- to set the z-index value from javascript to something bigger than 99999;
- to add a mouse over listener to the chart, which unfortunately is not available.
Does someone has an idea how I could fix this thing?
Alex
FUDForum. Page generated in 0.03849 seconds
