Home » Newcomers » Newcomers » Eclipse.ini
Eclipse.ini [message #1434259] Mon, 29 September 2014 22:15 Go to next message
Ooi Hee Kah is currently offline Ooi Hee KahFriend
I read this post:
If you've "installed" Eclipse but are having trouble getting it to run, the most likely cause is that you have not correctly specified the JVM for it to run under. Doing so is easy, just read http://wiki.eclipse.org/Eclipse.ini
Another common mistake (among Windows users) is a mismatch between the "bittedness" of Eclipse and the JVM/JDK. 64-bit Eclipse requires a 64-bit JVM, and 32-bit Eclipse requires 32-bit JVM. You can't mix-and-match 32-bit and 64-bit. So make sure the version of Eclipse you installed matches the JVM/JDK that you're using to run it (and make sure you're using eclipse.ini to specify the exact JVM used to run Eclipse, described above).
How to match the JVM/JDK in ellipse.ini
Re: Eclipse.ini [message #1434273 is a reply to message #1434259] Mon, 29 September 2014 22:43 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Not sure...but were you asking a question in there?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse.ini [message #1434693 is a reply to message #1434273] Tue, 30 September 2014 12:51 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
If you're using a 32-bit JDK/JRE, you must use 32-bit Eclipse. If you're using 64-bit JDK/JRE, you must use 64-bit Eclipse.
Previous Topic:Way over my head
Next Topic:Autosave in real time
Current Time: Mon Sep 21 16:55:39 GMT 2020
Powered by FUDForum. Page generated in 0.03260 seconds
