Re: [Xcore] What is the advantage of "derived feature" from "operation&am [message #1434002 is a reply to message #1433879] |
Mon, 29 September 2014 14:30 |
Ed Merks Messages: 33140 Registered: July 2009 |
Ravi,
Comments below.
On 29/09/2014 2:49 PM, Ravi Nallappan wrote:
> I like the fact I now able to specify behaviour in more natural way
> using Xcore on top of ecore. i.e less hacking on generated codes.
> Questions based on
> https://wiki.eclipse.org/Xcore#Specifying_a_Derived_Feature , how does
> this "derived String lastName get {...}" different from say defining
> an operation - "op String getLastName {..}", initially I was under
> impression that this works as lazy initialization - but from generated
> code, it does not have the actual attribute lastName, the calculation
> is done everytime lastName feature is called.
It's certainly not visibly different in the Java API, but reflectively,
it's a property, so you can see it in the properties view, for example.
> Additionally, "derived String lastName set {..}" how does this works?
> how do we access the set parameters?
It doesn't really work. I.e., it doesn't work at all, so while it's in
the grammar, there really no proper implementation for it. At some
point I'd like to be able to declare fields for the implementation class
(distinct from features which are reflectively visible)... But that's
not trivial and won't be done anytime soon...
> Thank You.
Ed Merks
Re: [Xcore] What is the advantage of "derived feature" from "operation&am [message #1434494 is a reply to message #1434002] |
Tue, 30 September 2014 06:54 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
On 29.09.14 07:30, Ed Merks wrote:
> Ravi,
> Comments below.
>> Hi,
>> Questions based on
a feature value is observable using Adapters which does not work for
operations.
Tom
FUDForum. Page generated in 0.02961 seconds
