Home » Modeling » TMF (Xtext) » avoid @SuppressWarnings("all") in Xtend batch compiler
avoid @SuppressWarnings("all") in Xtend batch compiler [message #1433817] Mon, 29 September 2014 09:22 Go to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
is there a way to avoid the generation of @SuppressWarnings("all") when
invoking the headless Xtend compiler? I don't mind this annotation, but
it looks like that this annotation will prevent Sonarqube from reporting
possible issues on the generated Java code (see
http://sonarqube.15.x6.nabble.com/sonarqube-findbugs-and-generated-sources-td5028237.html).
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: avoid @SuppressWarnings("all") in Xtend batch compiler [message #1433874 is a reply to message #1433817] Mon, 29 September 2014 10:58 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Lorenzo,
there is currently no generic way to disable that for Xtend. You can use
another GeneratorConfig for your own languages but Xtend will generate
@SuppressWarnings if no user-defined @SuppressWarnings is present.
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 29.09.14 11:22, schrieb Lorenzo Bettini:
> Hi
> cheers
> Lorenzo
Re: avoid @SuppressWarnings("all") in Xtend batch compiler [message #1433949 is a reply to message #1433874] Mon, 29 September 2014 12:58 Go to previous messageGo to next message
On 29/09/2014 12:58, Sebastian Zarnekow wrote:
> Hi Lorenzo,
> Best,
> Sebastian
Hi Sebastian
I tried to write this Xtend class
@SuppressWarnings("serial")
class XtendGreeting {
def greeting() {
"Hello, world."
def useEquals() {
// 2 findbugs issues:
// findbugs:DM_NUMBER_CTOR
// findbugs:EC_UNRELATED_TYPES
new Integer(0).equals("foo");
but the generated Java class still shows as follows:
public class XtendGreeting {
public String greeting() {
return "Hello, world.";
public boolean useEquals() {
Integer _integer = new Integer(0);
return _integer.equals("foo");
am I missing something?
cheers
Lorenzo
Xtext Book:
Re: avoid @SuppressWarnings("all") in Xtend batch compiler [message #1433959 is a reply to message #1433949] Mon, 29 September 2014 13:18 Go to previous messageGo to next message
Hmm obviously I'm the one who missed something. I expected it to use
your explicitly suppressed warnings, but apparently it doesn't work.
Could you please file a ticket and describe why you want to suppress the
suppress warnings annotation?
Sebastian
Am 29.09.14 14:58, schrieb Lorenzo Bettini:
>> Hi Lorenzo,
>> Best,
>> Sebastian
> Hi Sebastian
> def greeting() {
> "Hello, world."
> def useEquals() {
> cheers
> Lorenzo
Re: avoid @SuppressWarnings("all") in Xtend batch compiler [message #1433963 is a reply to message #1433959] Mon, 29 September 2014 13:22 Go to previous messageGo to next message
mh... I found this one (sorry I hadn't seen that before); is this related?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=363685
cheers
Lorenzo
Xtext Book:
Re: avoid @SuppressWarnings("all") in Xtend batch compiler [message #1434024 is a reply to message #1433963] Mon, 29 September 2014 15:01 Go to previous messageGo to next message
Hi Lorenzo,
yes this ticket is related to the issue at hand.
Best,
Sebastian
Am 29.09.14 15:22, schrieb Lorenzo Bettini:
> cheers
> Lorenzo
Re: avoid @SuppressWarnings("all") in Xtend batch compiler [message #1434053 is a reply to message #1434024] Mon, 29 September 2014 15:40 Go to previous messageGo to next message
On 29/09/2014 17:01, Sebastian Zarnekow wrote:
> Hi Lorenzo,
> Best,
> Sebastian
OK, then I'll add some information there
cheers
Lorenzo
Xtext Book:
Re: avoid @SuppressWarnings("all") in Xtend batch compiler [message #1436181 is a reply to message #1434053] Thu, 02 October 2014 14:17 Go to previous message
For the moment I'm using a workaround I documented here
http://www.lorenzobettini.it/2014/10/analyzing-xtend-code-with-sonarqube/
Xtext Book:
Previous Topic:IJvmModelInferrer is being called for a lexically invalid model
Next Topic:Unit Test cross reference from one DSL to another DSL
Current Time: Mon Jun 01 13:38:10 GMT 2020
Powered by FUDForum. Page generated in 0.05090 seconds
