Home » Newcomers » Newcomers » Eclipse doesn't start on Ibuntu 14.04 LTS
Eclipse doesn't start on Ibuntu 14.04 LTS [message #1432122] Fri, 26 September 2014 17:01 Go to next message
Myroslav Theowgp is currently offline Myroslav TheowgpFriend
I've installed Eclipse Kepler on Ubuntu 14.04LTS , just unpacked the archive downloaded from the original website to /opt folder, and when I open Eclipse the loading window pops up as expected but then nothing else happens it just hangs on my screen forever.
I've added -vm option to eclipse.ini file to specify the JVM for it to run under, it looks like this:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.200.v20140116-2212
-product
org.eclipse.epp.package.standard.product
--launcher.defaultAction
openFile
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
openFile
--launcher.appendVmargs
-vm
/usr/lib/jvm/java-1.7.0-openjdk-i386/bin/java
-vmargs
-Dosgi.requiredJavaVersion=1.6
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
but nothing has changed ...
I'm so frustrated...Why can't I run Eclipse ??? Please, help anyone...
Re: Eclipse doesn't start on Ibuntu 14.04 LTS [message #1432189 is a reply to message #1432122] Fri, 26 September 2014 19:28 Go to previous messageGo to next message
Tauno Voipio is currently offline Tauno VoipioFriend
Are you sure that there is no 32/64 bit mismatch between:
- Linux and Java,
- Java and Eclipse?
I have run Kepler under Ubuntu 14.04 LTS and I'm currently running Luna in the same system without a hitch.
Please wait patiently when starting. The startup splash screen will get a progress bar at the bottom of the image when the startup proceeds. I checked on my MacBook under VMware: The splash screen appeared in 3 s, the progress bar in 17 s, and the workbench in 40 s.
Tauno Voipio
Re: Eclipse doesn't start on Ibuntu 14.04 LTS [message #1433900 is a reply to message #1432122] Mon, 29 September 2014 11:41 Go to previous messageGo to next message
My system is 32 bit, I'm using 32 bit Eclipse version(this time tried to download form Eclipse website) and I've manually installed Java 32 bit though, when I run java -version in Terminal I get
java version "1.7.0"
Java(TM) SE Runtime Environment (build 1.7.0-b147)
Java HotSpot(TM) Server VM (build 21.0-b17, mixed mode)
and it doesn't give a hint about bit version of Java... I'm confused about whether it is 64 or 32.
I wait enough for it to load but it just doesn't(
Also I tried to reinstall Ubuntu and still the same problem...
Re: Eclipse doesn't start on Ubuntu 14.04 LTS [message #1434179 is a reply to message #1433900] Mon, 29 September 2014 19:42 Go to previous message
Did you read the installation instructions at
<https://wiki.eclipse.org/Eclipse/Installation>?
The initialization file looks good. Mine is similar for
Kepler on Kubuntu 12.04 LTS, without the -vm option.
It seems to me that your installation is a bit broken.
Did you download and/or decompress it in Windows?
There is a warning about Windows decompression
utility in the installation page.
Mine is in /usr/local/eclipse, but it should not matter
if it is in /opt/eclipse instead.
Have you tried to start it from command line?
Tauno Voipio
Previous Topic:Cannot post message
Next Topic:keyboard response a little slow (seems there is delay)
Current Time: Fri Jul 10 14:05:17 GMT 2020
Powered by FUDForum. Page generated in 0.02681 seconds
