Home » Modeling » Papyrus » How to underline static property/method in a class diagramm
How to underline static property/method in a class diagramm [message #1431373] Thu, 25 September 2014 15:52 Go to next message
Alexander Stey is currently offline Alexander SteyFriend
Hello together,
I puzzle for days how to get properties and methods in a class diagramm underlined, if they are static (i use papyrus with eclipse Luna- 4.4.0, OS is Lubuntu).
Thank you in advance for help
Kind regards
Alex
Re: How to underline static property/method in a class diagramm [message #1431489 is a reply to message #1431373] Thu, 25 September 2014 19:14 Go to previous messageGo to next message
Charles Rivet is currently offline Charles RivetFriend
It's showing underlined for me (Papyrus 1.0.1.v201409241327 on MacOS X), but the underline colour is very faint (almost invisible)... I had to show the diagram at 200% to make sure it was indeed underlined.
/Charles Rivet
[Updated on: Thu, 25 September 2014 19:15]
Report message to a moderator
Re: How to underline static property/method in a class diagramm [message #1432635 is a reply to message #1431489] Sat, 27 September 2014 12:53 Go to previous messageGo to next message
mh- I see (it now;)- at about 125% I am able to see a thin grey line. Anyway, I think it should be possible to change the color and the size of the line. I looked for possibiliites under the property tabs and under window > prefrences > papyrus, unfortunately without success.
Re: How to underline static property/method in a class diagramm [message #1433973 is a reply to message #1432635] Mon, 29 September 2014 13:45 Go to previous message
I agree wrt the formatting choice (or, at the very least, make it the same colour as the font).
I would suggest you enter a bug in bugzilla to get that fixed.
/Charles Rivet
Previous Topic:UML Papyrus: drawing a state transition in state machine diagram
Next Topic:Association default name
Current Time: Wed Mar 03 06:59:14 GMT 2021
Powered by FUDForum. Page generated in 0.02184 seconds
