Home » Modeling » EMF » EMF Maven repos (again)
EMF Maven repos (again) [message #1431124] Thu, 25 September 2014 08:33 Go to next message
Mauro Condarelli is currently offline Mauro CondarelliFriend
I searched, but found too many conflicting answers, so here I am.
I have a Project where I use EMF standalone.
Project is under Maven control.
I need (at least) the following EMF plugins/verions:
- org.eclipse.emf.common:2.9.0
- org.eclipse.emf.databinding:1.3.0
- org.eclipse.emf.databinding.edit:1.3.0
- org.eclipse.emf.ecore:2.9.0
- org.eclipse.emf.ecore.xmi:2.9.0
- org.eclipse.emf.edit:2.9.0
Some of those are available from http://mvnrepository.com/artifact/org.eclipse.emf, but others (e.g.: databinding) I couldn't find.
Can someone, pretty please, point me to the right repositor[y|ies]?
Context: up to now I developed using an in-house Nexus server where I uploaded the required bundles pulling them from the release, but now I need to deliver the code and Customer doesn't want to access "non standard" repositories, so I need to find the required Artifacts on the Internet.
Thanks in Advance
Mauro
Re: EMF Maven repos (again) [message #1431236 is a reply to message #1431124] Thu, 25 September 2014 11:40 Go to previous messageGo to next message
Guillaume Hillairet is currently offline Guillaume HillairetFriend
Member
The latest emf artefacts are available under the groups
org.eclipse.birt.runtime
http://search.maven.org/#search|ga|2|g%3Aorg.eclipse.birt.runtime and
org.eclipse.emf http://search.maven.org/#search|ga|1|g%3Aorg.eclipse.emf
On 2014-09-25 08:33:18 +0000, Mauro Condarelli said:
> Internet.
> Thanks in Advance
> Mauro
Re: EMF Maven repos (again) [message #1434951 is a reply to message #1431236] Tue, 30 September 2014 19:24 Go to previous messageGo to next message
Thanks Guillaume,
I found most of what I need, but not all :(
I am unable to find (versions are not mandatory, of course):
- org.eclipse.core.databinding.observable:1.4.1
- org.eclipse.core.databinding.property:1.4.200
What am I doing wrong?
NOTE: I found also references to server "maven.eclipse.org", which exists, but doesn't seem to respond; is it relevant?
Thanks in advance
Il 25/09/2014 13:40, Guillaume Hillairet ha scritto:
> The latest emf artefacts are available under the groups org.eclipse.birt.runtime http://search.maven.org/#search|ga|2|g%3Aorg.eclipse.birt.runtime and org.eclipse.emf http://search.maven.org/#search|ga|1|g%3Aorg.eclipse.emf
>> Hi,
>> Thanks in Advance
>> Mauro
Re: EMF Maven repos (again) [message #1435487 is a reply to message #1434951] Wed, 01 October 2014 15:10 Go to previous messageGo to next message
Member
I don't think those are available on maven.
On 2014-09-30 19:24:16 +0000, Mauro Condarelli said:
> Thanks Guillaume,
> Thanks in advance
>> Hi,
>>> Hi,
>>> Internet.
>>> Thanks in Advance
>>> Mauro
Re: EMF Maven repos (again) [message #1435930 is a reply to message #1435487] Thu, 02 October 2014 06:38 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Mauro,
I added most of the current emf core jars on search.maven.org and can/will also add the ones you miss. But... I can't
find the databinding.property or databinding.observable jar's in the standard EMF download. Where did you find those?
I used:
https://www.eclipse.org/modeling/emf/downloads/index.php?project=emf
gr. Martin
>> Thanks Guillaume,
>> Thanks in advance
>>> Hi,
>>>> Hi,
>>>> couldn't find.
>>>> Thanks in Advance
>>>> Mauro
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: EMF Maven repos (again) [message #1435948 is a reply to message #1435930] Thu, 02 October 2014 07:10 Go to previous messageGo to next message
Martin,
I assume he means org.eclipse.emf.databinding and
org.eclipse.emf.databinding.edit.
On 02/10/2014 8:38 AM, Martin Taal wrote:
> Hi Mauro,
> can/will also add the ones you miss. But... I can't find the
> I used:
> gr. Martin
>>> Thanks Guillaume,
>>> Thanks in advance
>>>> Hi,
>>>> and org.eclipse.emf
>>>>> Hi,
>>>>> couldn't find.
>>>>> Internet.
>>>>> Thanks in Advance
>>>>> Mauro
Ed Merks
Re: EMF Maven repos (again) [message #1435971 is a reply to message #1435948] Thu, 02 October 2014 07:50 Go to previous messageGo to next message
Okay, I published new versions of these jars to maven, they should be on search.maven.org within a day:
org.eclipse.emf.codegen.ecore 2.10.1-v20140901-1055
org.eclipse.emf.codegen 2.10.0-v20140901-1055
org.eclipse.emf.common 2.10.1-v20140901-1043
org.eclipse.emf.ecore 2.10.1-v20140901-1043
org.eclipse.emf.ecore.xmi 2.10.1-v20140901-1043
org.eclipse.xsd 2.10.0-v20140901-1055
org.eclipse.emf.mapping.ecore2xml 2.8.0-v20140901-1055
org.eclipse.emf.edit 2.10.1-v20140901-1055
org.eclipse.emf.databinding 1.3.0-v20140901-1055
org.eclipse.emf.databinding.edit 1.3.0-v20140901-1055
gr. Martin
On 02-10-14 09:10, Ed Merks wrote:
> Martin,
> I assume he means org.eclipse.emf.databinding and org.eclipse.emf.databinding.edit.
>> Hi Mauro,
>> I used:
>> gr. Martin
>>>> Thanks Guillaume,
>>>> Thanks in advance
>>>>> Hi,
>>>>>> Hi,
>>>>>> couldn't find.
>>>>>> Thanks in Advance
>>>>>> Mauro
The Netherlands
Re: EMF Maven repos (again) [message #1435972 is a reply to message #1435930] Thu, 02 October 2014 07:53 Go to previous messageGo to next message
Hi Martin,
I am using the efxclipse all-in-one release:
http://downloads.efxclipse.bestsolution.at/downloads/released/1.0.0/sdk/eclipse-SDK-4.4-win32-x86_64-efx-1.0.0-SNAPSHOT.zip
and I have nothing particularly exotic in my software sites:
http://download.eclipse.org/releases/luna/
http://download.eclipse.org/efxclipse/updates-nightly/site
http://download.eclipse.org/technology/m2e/releases
in particular the following jars are contained in the all-in-one package (it is unclear to me what You are missing):
org.eclipse.core.databinding.beans.source_1.2.200.v20140214-0004.jar
org.eclipse.core.databinding.beans_1.2.200.v20140214-0004.jar
org.eclipse.core.databinding.observable.source_1.4.1.v20140210-1835.jar
org.eclipse.core.databinding.observable_1.4.1.v20140210-1835.jar
org.eclipse.core.databinding.property.source_1.4.200.v20140214-0004.jar
org.eclipse.core.databinding.property_1.4.200.v20140214-0004.jar
org.eclipse.core.databinding.source_1.4.1.v20140214-0004.jar
org.eclipse.core.databinding_1.4.1.v20140214-0004.jar
org.eclipse.emf.databinding.edit.source_1.3.0.v20140519-0339.jar
org.eclipse.emf.databinding.edit_1.3.0.v20140519-0339.jar
org.eclipse.emf.databinding.source_1.3.0.v20140519-0339.jar
org.eclipse.emf.databinding_1.3.0.v20140519-0339.jar
They are also available in http://download.eclipse.org/efxclipse/runtime-nightly/site_assembly.zip
I don't know where Tom Schindl took them to prepare these releases.
Notice packages in site_assembly.zip seem to be recompiled nightly.
I humbly suggest You to strip the date information (fourth component of version) from whatever You upload to a standard repo.
Thanks in Advance
Mauro
Il 02/10/2014 08:38, Martin Taal ha scritto:
> Hi Mauro,
> I added most of the current emf core jars on search.maven.org and can/will also add the ones you miss. But... I can't find the databinding.property or databinding.observable jar's in the standard EMF download. Where did you find those?
> I used:
> gr. Martin
>>> Thanks Guillaume,
>>> Thanks in advance
>>>> Hi,
>>>>> Hi,
>>>>> couldn't find.
>>>>> Thanks in Advance
>>>>> Mauro
Re: EMF Maven repos (again) [message #1436040 is a reply to message #1435972] Thu, 02 October 2014 09:47 Go to previous messageGo to next message
Hi Mauro,
Has yes the date thing in the version is a mistake on my side. I guess the maven artifacts of these published releases
should be without timestamp. Corrected this, now published with corrected versions.
I am involved in the modeling part and can publish to maven for emf artifacts but I can't publish the org.eclipse.core
artifacts (no authorization for that group at sonatype).
gr. Martin
On 02-10-14 09:53, Mauro Condarelli wrote:
> Hi Martin,
> repo.
> Thanks in Advance
> Mauro
>> Hi Mauro,
>> I used:
>> gr. Martin
>>>> Thanks Guillaume,
>>>> Thanks in advance
>>>>> Hi,
>>>>>> Hi,
>>>>>> couldn't find.
>>>>>> Thanks in Advance
>>>>>> Mauro
The Netherlands
Re: EMF Maven repos (again) [message #1436160 is a reply to message #1436040] Thu, 02 October 2014 13:44 Go to previous message
Thanks Martin.
Do You know who (if anyone) can update org.eclipse.core.* artifacts?
What I can see searching Maven Central is *VERY* old!
Where should I request for a refresh?
Mauro
Il 02/10/2014 11:47, Martin Taal ha scritto:
> Hi Mauro,
> Has yes the date thing in the version is a mistake on my side. I guess the maven artifacts of these published releases should be without timestamp. Corrected this, now published with corrected versions.
> I am involved in the modeling part and can publish to maven for emf artifacts but I can't publish the org.eclipse.core artifacts (no authorization for that group at sonatype).
> gr. Martin
>> Hi Martin,
>> repo.
>> Thanks in Advance
>> Mauro
>>> Hi Mauro,
>>> I used:
>>> gr. Martin
>>>>> Thanks Guillaume,
>>>>> Thanks in advance
>>>>>> Hi,
>>>>>>> Hi,
>>>>>>> couldn't find.
>>>>>>> Thanks in Advance
>>>>>>> Mauro
Previous Topic:Example of extending an ecore model
Next Topic:how create CDO branches
Current Time: Fri Sep 18 10:36:48 GMT 2020
Powered by FUDForum. Page generated in 0.02011 seconds
