Home » Eclipse Projects » SWTBot » How to Click on a link under a CTabFolder? (How to Click on a link under a TabFolder? or right click on the empty space or link to get context menu?)
How to Click on a link under a CTabFolder? [message #1430711] Wed, 24 September 2014 14:04 Go to next message
I want to click on the link under a ctabfolder (that is what my spy view says). Then a new dialog window should be open.
OR
How do i right click on the empty space or link under the ctabfolder to get context menu?
I tried every possible way but i think the first issue is it doesn't even recognize the tabfolder.
index.php/fa/19251/0/
Here is my code:
tree = View.getTree("Servers");
link.click();
ERROR
org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 45000 ms.: The widget TreeItem with text {} was not enabled.
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:398)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:372)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:360)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.waitForEnabled(AbstractSWTBot.java:635)
how exactly should I write this of kind code in SWTbot?
The online doc does not help me in anyway.
Any help would be appreciated.
Thanks.
  • Attachment: link.PNG
    (Size: 11.14KB, Downloaded 1331 times)
Re: How to Click on a link under a CTabFolder? [message #1433720 is a reply to message #1430711] Mon, 29 September 2014 03:07 Go to previous messageGo to next message
I don't see a tree under this view...
I'd try
SWTBotView view = bot.viewByTitle("Servers");
view.show();
view.setFocus();
view.bot.link("No server [blah-blah]").click();
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: How to Click on a link under a CTabFolder? [message #1434238 is a reply to message #1433720] Mon, 29 September 2014 17:33 Go to previous messageGo to next message
Thanks Mickael. The code worked till the focus is set on servers.But fails to click the link.It complains that the widget was not found.
Here is the code I have :
view.show();
view.setFocus();
view.bot().link("No servers available.Define a new server from the new server wizard...").click();
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundException: Could not find widget.
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetAppears(SWTBotFactory.java:348)
at com.ibm.datatools.automation.swtbot.finders.Bot.waitUntilWidgetAppears(Bot.java:1)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.widget(SWTBotFactory.java:308)
at com.ibm.datatools.automation.swtbot.finders.Bot.widget(Bot.java:1)
at org.eclipse.swtbot.swt.finder.SWTBot.link(SWTBot.java:3664)
at com.ibm.datatools.automation.swtbot.finders.Bot.link(Bot.java:1012)
at org.eclipse.swtbot.swt.finder.SWTBot.link(SWTBot.java:3652)
at com.ibm.datatools.automation.swtbot.finders.Bot.link(Bot.java:1007)
at com.ibm.datatools.swtbot.tests.ims.transactionproject.TransactionTasks.createTransactionServer(TransactionTasks.java:330)
at com.ibm.datatools.swtbot.test.ims.common.testcases.TranProj.executeTest(TranProj.java:75)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:76)
at java.lang.reflect.Method.invoke(Method.java:607)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main(RemotePluginTestRunner.java:64)
at org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(UITestApplication.java:117)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(WorkbenchTestable.java:71)
at java.lang.Thread.run(Thread.java:781)
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 45000 ms.: Could not find widget matching: (of type 'Link' and with mnemonic '<a>No servers available.Define a new server from the new server wizard...')
at com.ibm.datatools.automation.swtbot.finders.Bot.waitUntil(Bot.java:1)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetAppears(SWTBotFactory.java:346)
... 36 more
Re: How to Click on a link under a CTabFolder? [message #1434652 is a reply to message #1434238] Tue, 30 September 2014 07:59 Go to previous messageGo to next message
Aren't you missing a space between the first dot and "Define" ?
Mickael Istria
Re: How to Click on a link under a CTabFolder? [message #1434962 is a reply to message #1434652] Tue, 30 September 2014 17:39 Go to previous message
Just the space didnt work but apparently it had some hidden characters which i could see only from a spy view.
This worked.
view.bot().link("<a>No servers available. Define a new server from the new server wizard...</a>").click();
Thanks Mickael again for the help.
[Updated on: Tue, 30 September 2014 18:18] by Moderator
Previous Topic:"WorkbenchTestable - No Classloader found for plug-in
Next Topic:How to test RCP application with login screen?
Current Time: Sat Jun 14 20:56:25 EDT 2025
Powered by FUDForum. Page generated in 0.06706 seconds
