.nfs file lock [message #1430486] |
Wed, 24 September 2014 12:34 |
Nimi Sukumaran Messages: 35 Registered: August 2013 Location: Bangalore |
Member |
Hi All,
I have faced a .nfs file lock issue in Hudson
Details:
I was running one of my hudson job of its 12th build. SVN check out has failed with below error .
svn: E175002: SSL peer shut down incorrectly
svn: E175002: REPORT request failed on '/svn/Wallet-Client-2-0-Android/!svn/vcc/default'
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:106)
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:90)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:662)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:286)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:274)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.performHttpRequest(DAVConnection.java:696)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.doReport(DAVConnection.java:328)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.runReport(DAVRepository.java:1287)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.update(DAVRepository.java:835)
at org.tmatesoft.svn.core.internal.wc2.ng.SvnNgAbstractUpdate.updateInternal(SvnNgAbstractUpdate.java:216)
at org.tmatesoft.svn.core.internal.wc2.ng.SvnNgAbstractUpdate.update(SvnNgAbstractUpdate.java:100)
at org.tmatesoft.svn.core.internal.wc2.ng.SvnNgAbstractUpdate.checkout(SvnNgAbstractUpdate.java:756)
at org.tmatesoft.svn.core.internal.wc2.ng.SvnNgCheckout.run(SvnNgCheckout.java:14)
at org.tmatesoft.svn.core.internal.wc2.ng.SvnNgCheckout.run(SvnNgCheckout.java:9)
at org.tmatesoft.svn.core.internal.wc2.ng.SvnNgOperationRunner.run(SvnNgOperationRunner.java:20)
at org.tmatesoft.svn.core.internal.wc2.SvnOperationRunner.run(SvnOperationRunner.java:20)
at org.tmatesoft.svn.core.wc2.SvnOperationFactory.run(SvnOperationFactory.java:1221)
at org.tmatesoft.svn.core.wc2.SvnOperation.run(SvnOperation.java:292)
at org.tmatesoft.svn.core.wc.SVNUpdateClient.doCheckout(SVNUpdateClient.java:781)
at hudson.scm.subversion.CheckoutUpdater$UpdateTaskImpl.perform(CheckoutUpdater.java:99)
at hudson.scm.subversion.WorkspaceUpdater$UpdateTask.delegateTo(WorkspaceUpdater.java:152)
at hudson.scm.SubversionSCM$CheckOutTask.perform(SubversionSCM.java:807)
at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:790)
at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:771)
at hudson.FilePath.act(FilePath.java:758)
at hudson.FilePath.act(FilePath.java:740)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:763)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:706)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1483)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:507)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:424)
at hudson.model.Run.run(Run.java:1366)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:145)
Caused by: javax.net.ssl.SSLException: SSL peer shut down incorrectly
at com.sun.net.ssl.internal.ssl.InputRecord.readV3Record(InputRecord.java:408)
at com.sun.net.ssl.internal.ssl.InputRecord.read(InputRecord.java:360)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:798)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:755)
at com.sun.net.ssl.internal.ssl.AppInputStream.read(AppInputStream.java:75)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:256)
at java.io.BufferedInputStream.read(BufferedInputStream.java:317)
at org.tmatesoft.svn.core.internal.util.ChunkedInputStream.read(ChunkedInputStream.java:75)
at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:264)
at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:306)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:158)
at java.io.InputStreamReader.read(InputStreamReader.java:167)
at org.tmatesoft.svn.core.internal.io.dav.http.XMLReader.read(XMLReader.java:39)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(XMLEntityScanner.java:1742)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.scanContent(XMLEntityScanner.java:916)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanContent(XMLDocumentFragmentScannerImpl.java:1591)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2902)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:140)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.readData(HTTPConnection.java:777)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.readData(HTTPConnection.java:742)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPRequest.dispatch(HTTPRequest.java:218)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:368)
Then I tried to wipe out the workspace , but it was saying that unabel to delete because of below error.
java.io.IOException: Unable to delete Build_job_name_path/workspace/.svn/.nfs00000000012cfbb90000545c
at hudson.Util.deleteFile(Util.java:263)
at hudson.Util.deleteRecursive(Util.java:305)
at hudson.Util.deleteContentsRecursive(Util.java:224)
at hudson.Util.deleteRecursive(Util.java:304)
at hudson.scm.subversion.CheckoutUpdater$UpdateTaskImpl.cleanupBeforeCheckout(CheckoutUpdater.java:137)
at hudson.scm.subversion.CheckoutUpdater$UpdateTaskImpl.perform(CheckoutUpdater.java:73)
Then I had to restart to get rid of this .nfs file lock.
But even after restart Hudson, the issue was persisting. For the temporary solution, we had to create a new job with the same configuration and run that job and it ran successfully.Please let me know why this behaviour and how to resolve this issue permanently.
kindly let me know if you need more information about this issue.
FUDForum. Page generated in 0.03238 seconds
