Bread Crumbs implementation location [message #253977] |
Mon, 16 June 2008 19:30 |
Originally posted by: Adam_Neal.ca.ibm.com
I'm interested to see how the Bread Crumbs feature was implemented. Could
someone please direct me where to look to see the implementation for this.
Thanks in advance,
Adam
JDT - no longer to launch/run Java application (run/debug settings window now empty) [message #253981 is a reply to message #253977] |
Mon, 16 June 2008 19:58 |
Originally posted by: mg4news.gmail.com
I have been using Ganymede, mainly the CDT. A while ago I added the JDT
to my configuration. I had been playing with a STaX (XML) example app
which was running fine. Normal sort of thing - create project - java
application, etc. Run as "java application"
I recently did an Eclipse update, and I can no longer run the
application. If I right-click on the main and select "run as" the only
option now is "run on server" - which doesn't work.
In project properties -> "run/debug settings" the launch configuration
window is empty. If I select "new" to add a configuration type, that
window is also empty.
I then created a new from scratch project - same results.
I then tried a different installation of Ganymede JDT, that one works fine.
I am trying to figure out what happened so I can resusitate my
environment. I am sure it is something simple/obvious/stupid.
MG
FUDForum. Page generated in 5.04033 seconds
