Home » Eclipse Projects » Eclipse 4 » Check if RCP App is in right-to-left mode?(Is there a way to properly check for rtl parameter?)
Check if RCP App is in right-to-left mode? [message #1428730] Mon, 22 September 2014 08:51 Go to next message
Alex Kipling is currently offline Alex KiplingFriend
I created a widdget which should position shells properly in rtl mode.
Is there a way to ask the platform for the orientation which it's started in?
I only found some related code in WorkbenchPlugin, but it's methods a private.
Re: Check if RCP App is in right-to-left mode? [message #1428927 is a reply to message #1428730] Mon, 22 September 2014 14:54 Go to previous message
Brian de Alwis is currently offline Brian de AlwisFriend
It looks like the JFace BidiUtils provides some support for querying the state, but from what I could see everything really comes down to checking JFace's Window#getDefaultOrientation().
Brian.
Previous Topic:EMF: Reuse existing Model
Next Topic:change main menu after opening a file
Current Time: Sat Feb 27 10:54:19 GMT 2021
Powered by FUDForum. Page generated in 0.02454 seconds
