Home » Newcomers » Newcomers » Eclipse hangs when executed
Eclipse hangs when executed [message #1426931] Fri, 19 September 2014 12:48 Go to next message
afa afa is currently offline afa afaFriend
Using Win7 64bit, Eclipse 64bit and JDK7 64bit.
I have -vm C:\Program Files\Java\jdk1.7.0_67\bin\javaw.exe in eclipse.ini and that is where my JDK is.
When I doubleclick eclipse.exe nothing happens, but my mouse cursor turns into the loading one whenever I mouse over the folder content of the eclipse root folder.
Task manager shows an unstoppable eclipse.exe process taking 96K of memory.
Whenever I open eclipse another time, another process appears.
Unpacked with Winrar to desktop.
How should I proceed with why is this happening?
Re: Eclipse hangs when executed [message #1427081 is a reply to message #1426931] Fri, 19 September 2014 17:22 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
In eclipse.ini, did you make sure to place -vm and the path to java.exe on 2 separate lines, as detailed on the wiki page?
[Updated on: Fri, 19 September 2014 17:22]
Report message to a moderator
Re: Eclipse hangs when executed [message #1427117 is a reply to message #1427081] Fri, 19 September 2014 18:38 Go to previous messageGo to next message
Yes, I tried that, but, the result was the same no matter how i put the -vm and where.
[Updated on: Fri, 19 September 2014 18:39]
Re: Eclipse hangs when executed [message #1427306 is a reply to message #1427117] Sat, 20 September 2014 01:50 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 09/19/2014 12:38 PM, afa afa wrote:
> Yes, I tried that, but, straight from the guide:
> "An alternative way is to insert the following VM option before the
> -vmargs option in the Eclipse shortcut properties(edit the field Target
> inside the "Shortcut" tab):
> -vm C:\jdk1.7.0_21\bin\javaw.exe
> or
> -vm C:\jdk1.7.0_21\jre\bin\java.exe "
I saw that too, but please do it this way:
-vm
Re: Eclipse hangs when executed [message #1427837 is a reply to message #1427306] Sat, 20 September 2014 22:16 Go to previous messageGo to next message
Yeah why would I even do it like that, my java in not there. And as I said, I did that and no change. I guess it's back to netbeans, since eclipse is so badly programmed.
Re: Eclipse hangs when executed [message #1428262 is a reply to message #1427837] Sun, 21 September 2014 14:51 Go to previous messageGo to next message
Roll with it, Afa. You replace the path with your path. The point was
the format of the option in eclipse.ini.
Re: Eclipse hangs when executed [message #1428339 is a reply to message #1428262] Sun, 21 September 2014 17:47 Go to previous message
Are you seriously so dumb or do you think me a total retard? Obviously this is a one in a million bug that will take more time and energy to solve than there's to gain from it. I'd rather drop the official android support and go with the user made plug-ins from Netbeans.
Previous Topic:Java Code Generator for CRUD classes
Next Topic:Help With Eclipse
Current Time: Mon Sep 21 19:35:07 GMT 2020
Powered by FUDForum. Page generated in 0.09487 seconds
