Home » Eclipse Projects » Nebula » Grid item updates
Grid item updates [message #24945] Tue, 30 January 2007 11:13 Go to next message
Marco Maccaferri is currently offline Marco MaccaferriFriend
I'm facing a weird problem with the Grid widget. Whenever I change the
text or color of a GridItem the UI is not updated immediately, but it is
updated after calling redraw.
This sounds a little weird to me, because I never call redraw on all
other widgets to update the text or colors. I was looking at the code
but I don't see any "update trigger" when changing the text, nor I see a
method to redraw only the updated item. What am I missing ?
Bye
Re: Grid item updates [message #25067 is a reply to message #24945] Tue, 30 January 2007 16:00 Go to previous messageGo to next message
Chris Gross is currently offline Chris GrossFriend
You're not missing anything. Its a bug. There should be a redraw() in
the various GridItem setters. It will be fixed in the next update.
-Chris
Marco Maccaferri wrote:
> Hello,
> Bye
Re: Grid item updates [message #26569 is a reply to message #25067] Sat, 03 February 2007 17:34 Go to previous messageGo to next message
I was asking because I'm experiencing some performance issues when Grid
needs to handle a huge amount of items. From what I see redraw repaints
the whole control (including the header, if I'm not wrong), so I was
wondering if there was some method to redraw only the items that were
updated.
If you plan to work on it, I think that it should be a good idea to
somehow flag the items that were updated and repaint only those.
Bye
Re: Grid item updates [message #26652 is a reply to message #26569] Mon, 05 February 2007 17:25 Go to previous message
Hi Marco,
Yes the Grid currently redraws the entire client area on every redraw.
But this will only draw rows in the visible range. So the number of
actual rows in the table shouldn't have much affect. How many rows do
you have?
-Chris
>> in the various GridItem setters. It will be fixed in the next update.
> updated.
> Bye
Re: Grid item updates [message #576242 is a reply to message #24945] Tue, 30 January 2007 16:00 Go to previous message
-Chris
> Hello,
> Bye
Re: Grid item updates [message #577235 is a reply to message #25067] Sat, 03 February 2007 17:34 Go to previous message
updated.
Bye
Re: Grid item updates [message #577317 is a reply to message #26569] Mon, 05 February 2007 17:25 Go to previous message
Hi Marco,
you have?
-Chris
> updated.
> Bye
Previous Topic:Implementing rowNumber in CompositeTable
Next Topic:Implementing rowNumber in CompositeTable
Current Time: Thu Oct 29 23:22:26 GMT 2020
Powered by FUDForum. Page generated in 0.02573 seconds
