Home » Modeling » EMF » [CDO] Legacy model changes not comitted
[CDO] Legacy model changes not comitted [message #1426601] Thu, 18 September 2014 21:00 Go to next message
I am using the Hibernate Store and QuickStart example to programaticaly get my object from server and make some changes and commit the transaction back. My model is a legacy model and I cannot regenrate and make it a CDOModel because the super classes are from alibrary that are not CDO models.
When I run the test with the CDO example model it works fine and it catches the changes and comitts makes the changes. However, when I run the same example on instances of my own model, after the first commit the changes on the model are not caught. As a result when I get the transactioninfo it has no commitdata.
When I try to use the EMF Editor and CDO Session viewer in Eclipse instance to create the model and make changes, it works fine and changes are committed.
I debugged in the code and I saw the isDirty flag doesn't get set when I call the setters in my object. Also, the eNotificationRequired in the setter returns false, which is because no Adapters are registered.
So I am wondering what I need to do to enable CDo on my legacy model for commits and updates programatically.
Also, if there is any way to regernate a cdo model that is extending a non-cdo model please let me know.
The code sample is:
final CDOSession session = openSession();
      final CDOTransaction transaction = session.openTransaction();
      // get/create a resource
      CDOResource resource = transaction.getOrCreateResource("/res4");
      // clear any previous data
      resource.getContents().clear(); //this sets the isDIrty to true
       MyClass1 res = MyFactory.eINSTANCE.MyClass1();
       res.setname("name");
       MyClass2 des = MyFactory.eINSTANCE.MyClass2();
       res.setRefObject(des);
       MyClass3 md= MyFactory.eINSTANCE.MyClass3();
       md.setComments("com1");
       md.setContactPerson("roza");
      resource.getContents().add(res);
      System.err.println(transaction.commit()); //the first commit works correctly
      md.setComments("new comment");
      md.setDesignDomain("dom1");
      System.err.println(transaction.commit()); //this commit doesn't catch any changes
Roza
[Updated on: Thu, 18 September 2014 21:05] by Moderator
Re: [CDO] Legacy model changes not comitted [message #1426796 is a reply to message #1426601] Fri, 19 September 2014 04:17 Go to previous messageGo to next message
If des and md only are referenced, they must be contained in a resource.
[Updated on: Fri, 19 September 2014 04:18] by Moderator
Re: [CDO] Legacy model changes not comitted [message #1426829 is a reply to message #1426601] Fri, 19 September 2014 05:18 Go to previous messageGo to next message
Are you changing meta classes and trying to commit "the changes"?
That would be something like this:
- make changes to a file on file system
- String.class.setName("xyz")
- save the file
Re: [CDO] Legacy model changes not comitted [message #1429057 is a reply to message #1426829] Mon, 22 September 2014 14:53 Go to previous messageGo to next message
both references are containment and also I am not changing metaclass I am just changing the attributes of my object instance. Any other thoughts?
[Updated on: Mon, 22 September 2014 14:54] by Moderator
Re: [CDO] Legacy model changes not comitted [message #1429461 is a reply to message #1429057] Tue, 23 September 2014 04:58 Go to previous messageGo to next message
You haven't added md anywhere. You can use CDOUtil.getCDOObject(eObject).cdoRevision(); to test if the item is contained anywhere. Or a println on an EObject returns something like Product1[TRANSIENT] <- not contained anywhere or Product1[NEW] <- contained but not commited yet. DIRTY means it is modified.
Re: [CDO] Legacy model changes not comitted [message #1429843 is a reply to message #1429461] Tue, 23 September 2014 16:43 Go to previous message
You are right, with that it worked. I need to see why it is not working with my editor.
I have another problem with ID which I will be positing in a different thread.
Roza
Previous Topic:[XCore] Can I reference a EAtribute of a Xcore model on another Xcore model (within the same package
Next Topic:[CDO] cast error from string to cdoid
Current Time: Sun Jul 20 09:41:09 EDT 2025
Powered by FUDForum. Page generated in 0.04448 seconds
