EMF Databinding for CheckboxTableViewer.checkedElements [message #1425766] |
Wed, 17 September 2014 20:25 |
I'm sure I just miss some little detail but I wasn't able to find it yet in the web.
I try to bind the checked elements of a checkboxtableviewer to an EMF model entity as follows:
IViewerObservableSet vChecked = ViewersObservables.observeCheckedElements(tableViewer, SomeClass.class);
IObservableList eChecked = EMFObservables.observeList(settings,
ModelPackage.eINSTANCE.getSettings_Source());
bindingContext.bind[Set|List|Value](vChecked, eChecked);
Unfortunately this does not compile since I'm not allowed to mix IViewerObservableSet (which comes from ViewersObservables.observeCheckedElements) and IViewerObservableList (which comes from EMFObservables.observeList). There is no such thing like EMFObservables.observeSet, so I'm a bit lost at the moment.
Any advice would be greatly appreciated.
Marcel
[Updated on: Wed, 17 September 2014 20:27] Report message to a moderator
Re: EMF Databinding for CheckboxTableViewer.checkedElements [message #1425808 is a reply to message #1425766] |
Wed, 17 September 2014 21:46 |
Okay, I found the solution in Tom Seidel's remus project:
public class List2SetConverter {
public static IObservableSet create(final IObservableList source) {
final IObservableSet set = new WritableSet(source, null);
source.addListChangeListener(new IListChangeListener() {
public void handleListChange(final ListChangeEvent event) {
event.diff.accept(new ListDiffVisitor() {
public void handleRemove(final int index, final Object element) {
set.remove(element);
public void handleAdd(final int index, final Object element) {
set.add(element);
set.addSetChangeListener(new ISetChangeListener() {
public void handleSetChange(final SetChangeEvent event) {
SetDiff diff = event.diff;
source.addAll(diff.getAdditions());
source.removeAll(diff.getRemovals());
return set;
which then allows me to do:
IViewerObservableSet vChecked = ViewersObservables.observeCheckedElements(viewer, Type.class);
IObservableSet eChecked = List2SetConverter.create(EMFObservables.observeList(settings, ModelPackage.eINSTANCE.getSettings_Source()));
bindingContext.bindSet(vChecked, eChecked);
Marcel
Re: EMF Databinding for CheckboxTableViewer.checkedElements [message #1426146 is a reply to message #1426144] |
Thu, 18 September 2014 10:00 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
on another note by default multi-valued features fullfill the Set
contract so we might do better than copying stuff around and make the
observable we create also implement the IObservableSet semantics and so
reduce the copying done (in your and the ListToSetAdapter approach).
You can file a bugzilla - I can not promise I have the time to implement
it but so at least we don't forget about it ;-)
Tom
On 18.09.14 11:56, Tom Schindl wrote:
> There's util class in core.databinding.observable which is named
> ListToSetAdapter.
> Tom
>> @Override
>> @Override
>> Object element) {
>> @Override
>> element) {
>> set.add(element);
>> @Override
>> return set;
>> Marcel
FUDForum. Page generated in 0.02647 seconds
