Home » Eclipse Projects » Eclipse 4 » Listening for Activation of new childcontext?(Is it possible to listen for activation of new child contexs?)
Listening for Activation of new childcontext? [message #1425393] Wed, 17 September 2014 08:41 Go to next message
Alex Kipling is currently offline Alex KiplingFriend
GIven a hierarchy of COntexts
ContextParent
- ContextChild1
- ContextChild2
- ContextChild3
- ContextChild4
Can I somehow listen, whether a new Child of "ContextParent" was activated?
Re: Listening for Activation of new childcontext? [message #1425399 is a reply to message #1425393] Wed, 17 September 2014 08:51 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
I'm not 100% sure but @Active might give you this information, let's
suppose you have a class ContextTracker create on ContextParent then you
should get the current active context maybe through
@Inject
public void contextSwitched(@Active IEclipseContext c) {
if the above does not work the only chance I see is that in each
child-context you store the context itself e.g. in the key
"my_active_child" and then the above looks like
@Inject
public void contextSwitched(@Active @Named("my_active_child")
For a short intro to @Active look at
http://tomsondev.bestsolution.at/2013/01/30/active-in-e4/
Tom
> ContextParent
> - ContextChild1
> - ContextChild2
> - ContextChild3
> - ContextChild4
Re: Listening for Activation of new childcontext? [message #1426318 is a reply to message #1425399] Thu, 18 September 2014 15:06 Go to previous message
Thnx Thomas!
I solved it by tracking a concrete Object in Active context,
because I wished t omodify the context.
On modification the context is reinjected, which caused an infinite loop.
The method with a special (@Named Object ) worked too!
void trackActivePageInitializer(@Optional @Active IEditorPageInitializer editorPageInitializer) {
Previous Topic:Problem with Property page
Next Topic:Adding my own pseudo classes to e4 CSS support?
Current Time: Fri Feb 26 00:56:23 GMT 2021
Powered by FUDForum. Page generated in 0.02288 seconds
