Home » Language IDEs » Java Development Tools (JDT) » Running external launch program(Launching non-standard Java app from Eclipse)
Running external launch program [message #1424373] Mon, 15 September 2014 22:24 Go to next message
Kenzie Togami is currently offline Kenzie TogamiFriend
I want to run my code through Gradle before it is run so that tokens can be replaced and a few other things from Gradle can be applied. However, I am not sure of the best way to have the 'Run' button launch Gradle. I configured Gradle as the auto-builder, and I could have it also be the manual builder so when I run manual builds it launches, but that would be terrible workflow. Is there a way to integrate the launch?
Re: Running external launch program [message #1425541 is a reply to message #1424373] Wed, 17 September 2014 13:03 Go to previous messageGo to next message
Jean Luc Boeuf is currently offline Jean Luc BoeufFriend
Hi!
Sorry for my question but what is Gradle exactly? When I'm runing internal program with java in eclipse I call the launcher then i write some command on it. That is a very easy way.
____________________________________________________________________________________________________________________
Jean Luc Boeuf
Re: Running external launch program [message #1431069 is a reply to message #1425541] Thu, 25 September 2014 07:05 Go to previous message
Sarika Sinha is currently offline Sarika SinhaFriend
Have you tried configuring an external builder in "Builders" Preferences for a project ?
This can help you specify the additional builders for a project in defined order.
Sarika Sinha
JDT Programmer
Previous Topic:Java to Objective-C compiler
Next Topic:Custom processing after build but before copy
Current Time: Mon Apr 22 20:02:05 GMT 2024
Powered by FUDForum. Page generated in 0.03304 seconds
