Home » Archived » Maven Integration (M2E) » conflicts when installing m2eclipse
conflicts when installing m2eclipse [message #24755] Wed, 01 April 2009 18:37
Rafael Chaves is currently offline Rafael ChavesFriend
I was having problems trying to install m2eclipse on an install that
already had Subversive. I found several similar reports elsewhere.
Luckily, I found a workaround: uninstalling Subversive and then installing
both Subversive and M2Eclipse at the same time worked fine.
This issue has been reported to the p2 team:
http://bugs.eclipse.org/270666
Just in case others have encountered the same problem.
Rafael
Previous Topic:Disable download from local repository?
Next Topic:Re: WTP project configuration is failing
Current Time: Fri Jul 19 01:24:40 GMT 2019
Powered by FUDForum. Page generated in 0.02593 seconds
