Home » Modeling » M2T (model-to-text transformation) » UML2Java Example "Can't find bundle"
UML2Java Example "Can't find bundle" [message #1420774] Wed, 10 September 2014 09:03 Go to next message
When running UML2Java example by right-clicking on model.uml and select "Run-As Acceleo application", I have the following error :
java.util.MissingResourceException: Can't find bundle for base name platform:/plugin/org.eclipse.acceleo.examples.uml2java/org/eclipse/acceleo/examples/uml2java/properties/default.properties, locale fr_FR
I work with Eclipse Luna "modeling packaging".
The application is launched as a Java Application.
When lauched as a plug-in application, nothing is generated.
Please, I need some help.
Thanks.
Re: UML2Java Example "Can't find bundle" [message #1420794 is a reply to message #1420774] Wed, 10 September 2014 09:39 Go to previous messageGo to next message
There have been a number of postings discussing the
limited/non-functionality of Launch as Acceleo application, so ignore
those errors; it doesn't work.
launch as plugin application should work, so that is what you should debug.
Ed Willink
On 10/09/2014 14:03, Missing name Mising name wrote:
> locale fr_FR
> Thanks.
Re: UML2Java Example "Can't find bundle" [message #1420813 is a reply to message #1420794] Wed, 10 September 2014 10:11 Go to previous messageGo to next message
Do you mean that running UML2Java outside of Eclipse does not work also ?
Re: UML2Java Example "Can't find bundle" [message #1420912 is a reply to message #1420813] Wed, 10 September 2014 13:13 Go to previous message
No.
Previous Topic:EditorAction on Acceleo-Editor
Next Topic:code generation for object c
Current Time: Wed Mar 19 18:00:51 EDT 2025
Powered by FUDForum. Page generated in 0.03210 seconds
