Home » Eclipse Projects » RCP Testing Tool » RCPTT Jenkins integration
RCPTT Jenkins integration [message #1420118] Tue, 09 September 2014 10:19 Go to next message
Hi, I'm currently trying to integrate RCPTT into my project. I currently use Jenkins for continuous integration. Is it possible to integrate RCPTT automated test with Jenkins? If not will there be any sollution for this in the near future?
Re: RCPTT Jenkins integration [message #1420249 is a reply to message #1420118] Tue, 09 September 2014 14:37 Go to previous messageGo to next message
Hi Alin,
RCPTT is a testing tool that allows you to design tests and run them manually. There is commercial product Continuous Integration for RCPTT by Xored (http://ci.xored.com/) or you can use solutions from other vendors.
Ivan
Re: RCPTT Jenkins integration [message #1692782 is a reply to message #1420249] Sat, 18 April 2015 05:54 Go to previous messageGo to next message
Hi Ivan,
do you have examples of the solutions from other vendors. Are there any non-commercial solutions to run RCPTT tests headless? I couldn't find any.
Andreas
Re: RCPTT Jenkins integration [message #1692790 is a reply to message #1692782] Sat, 18 April 2015 12:58 Go to previous messageGo to next message
Hello Andreas,
Thank you for contacting us!
RCPTT Test Runner is Open Source now.
You can find more information here.
It can be downloaded from nightly builds.
Documentation is available here.
Re: RCPTT Jenkins integration [message #1692860 is a reply to message #1692790] Mon, 20 April 2015 05:43 Go to previous messageGo to next message
Hi Olga,
I was setting it up to use the new open source build of the Test Runner. Is there an online repository where that build can be retrieved by Jenkins instead of using the <explicit> tags for runner?
cheers!
Joseph
Re: RCPTT Jenkins integration [message #1692863 is a reply to message #1692860] Mon, 20 April 2015 05:57 Go to previous messageGo to next message
Unfortunately online repository isn't available now.
It will be added with the Mars release.
Re: RCPTT Jenkins integration [message #1692978 is a reply to message #1692863] Mon, 20 April 2015 23:17 Go to previous messageGo to next message
thanks for the update Olga. happy to hear that Smile
cheers!
Re: RCPTT Jenkins integration [message #1693171 is a reply to message #1692978] Wed, 22 April 2015 04:47 Go to previous messageGo to next message
I am able to run the Test runner in Jenkins and it works. Smile
Re: RCPTT Jenkins integration [message #1695021 is a reply to message #1693171] Mon, 11 May 2015 08:53 Go to previous messageGo to next message
hi,
i am trying to run rcptt Test runner through jenkins,
i am using windows batch command in Jenkins to execute build, i see the AUT is not launched during script execution.
Is there any settings need to be done, to start AUT via jenkins ??
thanks in advance
Raghav
Re: RCPTT Jenkins integration [message #1695125 is a reply to message #1695021] Tue, 12 May 2015 04:01 Go to previous messageGo to next message
Hi Raghav,
Did you turn on Xvnc in your Jenkins job? You need that.
Jeevan
Re: RCPTT Jenkins integration [message #1695184 is a reply to message #1695021] Tue, 12 May 2015 10:16 Go to previous message
Could you please attach console log and runner output?
Did you try to use RCPTT Maven Plugin?
Previous Topic:Reading csv-file from workspace
Next Topic:ECL Verification
Current Time: Wed Jul 16 11:25:06 EDT 2025
Powered by FUDForum. Page generated in 0.34039 seconds
