Home » Archived » Test and Performance Tools Platform (TPTP) » Sample HyadesLoggingLog4JSample
Sample HyadesLoggingLog4JSample [message #24709] |
Wed, 03 August 2005 06:18 |
Originally posted by: akuhn.arcor.de
i am currently trying out all the samples of TPTP 4.0.
I was able to run the samples LogParser, LogCorrelator, LogAnalyzer and
AnalysisEngine as supposed from the Help.
But i have problems getting the HyadesLoggingLog4jSample to work.
I am able to compile and run it, i get the CBE Output on the Console
(from the ConsoleAppender in the xml config), but i am not able to do
'Attach Java Process', because in the 'Agent' tab of the configuration
(Profile-Atach Process) there is no logging agent showing up :(
I looked at the SourceCode of
org.eclipse.hyades.logging.log4j.LoggingAgentAppender and saw, that a
LoggingAgent instance should be created, so i assume this should work.
RAC is running and i cannot find any exception.
Any hints ?
Andi
Re: Sample HyadesLoggingLog4JSample [message #24753 is a reply to message #24709] |
Wed, 03 August 2005 12:43 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Andi,
Thanks for exploring the TPTP logging samples.
Did you enable logging in the Profiling and Logging preferences (Window
> Preferences... > Profiling and Logging > Enable logging > OK) as specified
in step #3 of the sample's readme? If so, please attach the Agent
Controller's log file (<Agent Controller's installation
directory>/config/servicelog.log) and TPTP build ID for review.
Paul
"Andi Kuhn" <akuhn@arcor.de> wrote in message
news:d2892e5ed6f5df3cd313838833ddc1a4$1@www.eclipse.org...
> Any hints ?
> Andi
Re: Sample HyadesLoggingLog4JSample [message #25038 is a reply to message #24753] |
Wed, 03 August 2005 18:00 |
--------------080703090809010003030508
Hi Paul,
yes, Logging is enabled.
I removed the log file, so that a clean one was created - also set
level to DEBUG.
I then started the application, the console showed the CBEs and the
text to attach now.
I openeded the Profile-Attach Process dialog, pusehd Test Connection to
be sure the RAC is listening on localhost:10002 and then pushed Refresh
in the agents tab, but no entry appeared...
I loaded the servicelog.log into the LogView but it seems ok, just some
warning about missing plugins, but recovered by correct version appended.
Andi
Paul Slauenwhite wrote:
> Hi Andi,
> Paul
>>Hi,
>>Any hints ?
>>Thanks,
>>Andi
Content-Type: text/x-log;
name="servicelog.log"
Content-Disposition: inline;
filename="servicelog.log"
<CommonBaseEvent creationTime="2005-08-03T13:44:15.504000Z" globalInstanceId="ADDE3844E32D4F0EA7F24E629A7D1309" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="10.97.30.31" locationType="IPV4" processId="3164" subComponent="..\RAServerConfig\RAServerConfigBinding2.cpp" componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A016770271664358980C66DFB81D70DC" msg="Using plugin directory C:\Entwicklung\raserver4\plugins" severity="5" version="1.0.1">
<extendedDataElements name="file" type="string">
<values>..\RAServerConfig\RAServerConfigBinding2.cpp</values >
</extendedDataElements>
<extendedDataElements name="line" type="int">
<values>328</values>
<extendedDataElements name="severity" type="string">
<values>DEBUG</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A8FF8D51DBD04F3D8C3E1F7312AFE990" msg="Adding org.apache.jakarta_commons_logging_1.0.3 to the available list of loadable plugins" severity="5" version="1.0.1">
<values>1185</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A5B76481A2994168A850C6D5058F0F25" msg="Adding org.eclipse.hyades.execution_4.0.0 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="AD92ABA080974BE7B901F1717A233145" msg="Adding org.eclipse.hyades.logging.adapter_4.0.0 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A130F5586E3D482AAFB3DEDCF7FF0C29" msg="Adding org.eclipse.hyades.logging.core_4.0.0 to the available list of loadable plugins" severity="5" version="1..0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A13E9FD27EB34A59945265755315B2EF" msg="Adding org.eclipse.hyades.logging.parsers_4.0.0 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="ADC6888A3AD54657893947DAD138BDA2" msg="Adding org.eclipse.hyades.perfmon.agents_4.0.0 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A5FD094FD7CE48C99AD015EA215F8332" msg="Adding org.eclipse.hyades.test.core_4.0.0 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A5281FCB87C14BA6A665853688702709" msg="Adding org.eclipse.hyades.test.tools.core_4.0.0 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="AD53060C117643B8AD8A3A9DA8D7A1C2" msg="Adding org.eclipse.tptp.platform.collection.framework_4.0.0 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="AC381063E3A04D28BF3A22AEE6B1B9F3" msg="Adding org.eclipse.tptp.platform.models_4.0.0 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="AA4366A620D54F448068851C5796310A" msg="Adding org.junit_3.8.1 to the available list of loadable plugins" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="AC2B551122B4436EB1BC965014A57D1C" msg="Start processing plugin: org.apache.jakarta_commons_logging_1.0.3" severity="10" version="1.0.1">
<values>374</values>
<values>INFORMATION</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A6F2884681E94485B0CEB7162C630B22" msg="Plugin loader: Config file for plugin: org.apache.jakarta_commons_logging_1.0.3 not found" severity="30" version="1.0.1">
<values>422</values>
<values>WARNING</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A8D65799D2AF44128C497FE8FA29129E" msg="Finished processing plugin: org.apache.jakarta_commons_logging_1.0.3" severity="10" version="1.0.1">
<values>376</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="AE00240815B34D57AA3B2B9601F529D2" msg="Start processing plugin: org.eclipse.hyades.execution_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="ACBDBF89027C4B6E94C94E2DBAAB20F1" msg="Started processing Configuration C:\Entwicklung\raserver4\plugins\org.eclipse.hyades.executio n_4.0.0\config\pluginconfig.xml " severity="5" version="1.0.1">
<values>140</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.544000Z" globalInstanceId="A4657E7A94BE40D09F640907CAE8C4A2" msg="Completed processing Configuration C:\Entwicklung\raserver4\plugins\org.eclipse.hyades.executio n_4.0.0\config\pluginconfig.xml " severity="5" version="1.0.1">
<values>147</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A228BD0918D64966B4892CBDB07508E0" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.execution_4.0.0 loaded successfully" severity="10" version="1.0.1">
<values>437</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A4D14039CAA14AC5B692D04967D24F94" msg="Finished processing plugin: org.eclipse.hyades.execution_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="ABFF8B051D9C430AA5A095CF0E80E565" msg="Start processing plugin: org.eclipse.hyades.logging.adapter_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A7E5F82801874827A2AB396B20B3070C" msg="Started processing Configuration C:\Entwicklung\raserver4\plugins\org.eclipse.hyades.logging. adapter_4.0.0\config\pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="AE877C430E3948C1928A9A8AA48ABF3E" msg="Completed processing Configuration C:\Entwicklung\raserver4\plugins\org.eclipse.hyades.logging. adapter_4.0.0\config\pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A64DF17790704D23881AB6E714A21032" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.logging.adapter_4.0.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="AE3B00C2949045D5913467065FA68EFC" msg="Finished processing plugin: org.eclipse.hyades.logging.adapter_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A4263B5A0A2A4340A87FA83A12C1D9F2" msg="Start processing plugin: org.eclipse.hyades.logging.core_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A31D330B0C594F25B1DBF379751DF648" msg="Started processing Configuration C:\Entwicklung\raserver4\plugins\org.eclipse.hyades.logging. core_4.0.0\config\pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A9223CF3C6B445F0B9CAEE7A76A4BB3C" msg="This plugin is dependent on org.eclipse.hyades.execution" severity="10" version="1.0.1">
<values>..\RAServerConfig\RAServerConfigHandler2.cpp</values >
<values>1118</values>
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="10.97.30.31" locationType="IPV4" processId="3164" subComponent="..\RAServerConfig\RAServerConfigHandler2.cpp" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A80A8499568B4B90AD9ACC0E8A34E303" msg="Plugin loader: Plugin: org.eclipse.hyades.execution not found" severity="30" version="1.0.1">
<values>418</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="AE007CB13597485591275603DDAFED82" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.execution_4.0.0" severity="30" version="1.0.1">
<values>1151</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A8E368803CB6463BB97CC3CF8EA73A91" msg="Plugin org.eclipse.hyades.execution_4.0.0 already loaded" severity="10" version="1.0.1">
<values>403</values>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A8A106D73BD046E3847DA6B98C3F7E5E" msg="Completed processing Configuration C:\Entwicklung\raserver4\plugins\org.eclipse.hyades.logging. core_4.0.0\config\pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A35CD32E5E85401FA419E6F5E3B74F3A" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.logging.core_4.0.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A74D9D36C6504B4FA974BD6E243B52E3" msg="Finished processing plugin: org.eclipse.hyades.logging.core_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="ADBBBDE3A3044C1EB3E280ED25D198BC" msg="Start processing plugin: org.eclipse.hyades.logging.parsers_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A5A149265EF94E5BB72F53EA83E8FCCE" msg="Started processing Configuration C:\Entwicklung\raserver4\plugins\org.eclipse.hyades.logging. parsers_4.0.0\config\pluginconfig.xml " severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="AE469F32853249EE8D65F70247AA30F3" msg="This plugin is dependent on org.eclipse.hyades.logging.core" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A774FAD729F740FA9D425DCEFFF89DA4" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.core not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A69D2F35A39D4BE0B1C91016029E29F8" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.core_4.0.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-08-03T13:44:15.554000Z" globalInstanceId="A987748244574C5EB91D3CC1647C58A0" msg="Plugin org.eclipse.hyades.logging.core_4.0.0 already loaded" severity="10" version="1.0.1">
<values>INFORMATION</values&g
Re: Sample HyadesLoggingLog4JSample [message #25278 is a reply to message #25038] |
Thu, 04 August 2005 16:58 |
Hi Andi,
Using the TPTP 4.0 driver
(http://www.eclipse.org/tptp/home/downloads/drops/4.0.0.html) the Log4J
sample works as expected. Can you open a defect
(https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP) for this problem
and include the below log file and also the driver version and build date.
Paul
"Andreas Kuhn" <akuhn@arcor.de> wrote in message
news:dcr0n9$6i2$1@news.eclipse.org...
> Hi Paul,
> level to DEBUG.
> text to attach now.
> Andi
> > Hi Andi,
(Window
specified
> > Thanks,
> > Paul
> >>Hi,
> >>Any hints ?
> >>Thanks,
> >>Andi
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
Configuration
luginconfig.xml" severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
Configuration
nfig\pluginconfig.xml" severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
Configuration
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
Configuration
> </situation>
> </CommonBaseEvent>
Re: Sample HyadesLoggingLog4JSample [message #25404 is a reply to message #25278] |
Thu, 04 August 2005 18:11 |
Hi Paul,
that's exactly the version i am using ( it is the official 'final' 4.0,
isn't it?)
Today i tried it on my linux box ( first test was on windows xp),
and on my first try i got an agent in the agent tab ( i think it was
just called java.exe).
I connected to it, changed to the LogView, but then the 30sec had
passed, the application died :(
So i increased the time to 300 sec and tried again, but from then on, i
didn't get an agent anymore !!?? :((
I am confused, but don't know what i am doing wrong :(
I think i did everything as described in the sample help.
how does it work internally?
The application logs to log4j, the config has the TPTP log4j appender
configured and this creates a LoggingAgent.
How is this LoggingAgent related to the RAC. Does it just register there
or is it somehow 'send' to the RAC. I didn't really understand the
connections here (how the stuff works together).
When i attach to the agent, i connect to the RAC, the RAC somehow knows
about the LoggingAgent, but it is running now on the RAC or does the RAC
just communicate with the Application i started ?
Andi
> Hi Andi,
> Paul
>>Hi Paul,
>>level to DEBUG.
>>text to attach now.
>>Andi
>>>Hi Andi,
> (Window
> specified
>>>Thanks,
>>>Paul
>>>>Hi,
>>>>Any hints ?
>>>>Thanks,
>>>>Andi
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
> version="1.0.1">
>></situation>
>></CommonBaseEvent>
> version="1.0.1">
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
> version="1.0.1">
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
> Configuration
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
> version="1.0.1">
>></situation>
>></CommonBaseEvent>
> Configuration
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
> version="1.0.1">
>></situation>
>></CommonBaseEvent>
> version="1.0.1">
>></situation>
>></CommonBaseEvent>
> Configuration
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
> version="1.0.1">
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
> version="1.0.1">
>></situation>
>></CommonBaseEvent>
>></situation>
>></CommonBaseEvent>
>>&l
Re: Sample HyadesLoggingLog4JSample [message #25488 is a reply to message #25404] |
Thu, 04 August 2005 18:51 |
Hi Andi,
The Logging Agent is a XML-based messaging agent that resides in the
Agent Controller. The Logging Agent appender converts the logged Common
Base Events to XML and logs them XML fragments to an instance of the Logging
Agent for local/remote clients (i.e. TPTP workbench) to attach.
When you installed the Agent Controller, did you add the <Agent
Controller's installation directory>/bin directory to the system's PATH
(i.e. Start >> Settings... >> Controller Panel >> System >> Advanced >>
Environment Variables >> Systems Variables >> Path on Windows XP)?
Paul
news:dctl4m$11k$1@news.eclipse.org...
> Hi Paul,
> isn't it?)
> Andi
> > Hi Andi,
problem
date.
> > Thanks,
> > Paul
> >>Hi Paul,
> >>level to DEBUG.
> >>text to attach now.
appended.
> >>Andi
> >>>Hi Andi,
> > (Window
> > specified
> >>>Thanks,
> >>>Paul
> >>>>Hi,
and
> >>>>Any hints ?
> >>>>Thanks,
> >>>>Andi
starting"
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
loadable
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
loadable
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
loadable
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
loadable
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
loadable
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
list
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
> > version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
found"
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
> > version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
> > Configuration
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
> > version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
> > Configuration
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
> > version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
> > version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
processing
> > Configuration
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
version="1.0.1">
> > processId="3164"
> >></situation>
> >></CommonBaseEvent>
> > version="1.0.1">
> > processId="3164"
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #25607 is a reply to message #25488] |
Thu, 04 August 2005 21:16 |
i solved the problem by adding an environment variable to the
'environment' Tab of the Run...->Java Application (when starting the
HyadesLoggingLog4JSample class).
On Linux i added LD_LIBRARY_PATH=${RASERVER_HOME}/lib which contains
native library that is needed by the LoggingAgent class.
Didn't try it out on windows yet...
Andi
> Hi Andi,
> Paul
>>Hi Paul,
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #25741 is a reply to message #25607] |
Fri, 05 August 2005 12:52 |
Hi Andi,
Great news! This required configuration is noted in the Agent
Controller's getting_started.html for each platform. For example, in the
Linux (x86) getting_started.html:
Prerequisites
a.. RAServer requires the directories of the JRE that contain executable
libraries such as libjvm.so to be added to the LD_LIBRARY_PATH environment
variable. For example, if you are using the IBM JRE 1.4.1, the
LD_LIBRARY_PATH variable would be set as follows:
export
LD_LIBRARY_PATH=/opt/IBMJava2-141/jre/bin/classic:/opt/IBMJa va2-141/jre/bin:
$LD_LIBRARY_PATHNote: The path that contains the JVM library libjvm should
match the one specified inside Agent Controller's configuration file,
config/serviceconfig.xml, under the AgentControllerConfiguration element's
jvm attribute. For example, if the configuration file is pointing to the
server JVM, then the library path should also point to the location of the
server JVM, not the client JVM. Agent Controller will not function properly
if the library path and the configuration do not match.
b.. The Agent Controller is compiled using libstdc++-libc6.2-2.so.3 shared
library. Ensure that this shared library exists under the /usr/lib
directory. If it does not exist, you have to install the RPM package
compat-libstdc++ that comes with the operating system installation media.
c.. Install the TPTP 4.0.0 Runtime.
Configuring and starting Agent Controller
Notation
<unzip directory> = The absolute directory path where Agent Controller has
been unzipped. For example, /opt/TPTP.
<RAServer PID> = The process identifier for the server process.
1.. Add the <unzip directory>/lib directory to the system's
LD_LIBRARY_PATH environment variable.
2.. Add the <unzip directory>/bin directory to the system's PATH
3.. Set the RASERVER_HOME environment variable to point to <unzip
directory>. The server will use this environment variable to locate the
configuration file.
4.. Ensure that the files in the <unzip directory>/bin and <unzip
directory>/lib directory are executable.
5.. Generate the configuration file that provides the rules for the
applications that can be executed by the server. This can be accomplished by
running the <unzip directory>/bin/SetConfig.sh script. Run this script from
a command shell in the <unzip directory>/bin directory.
6.. Start the server by changing your working directory to <unzip
directory>/bin and running ./RAStart.sh.
7.. Stop the server by changing your working directory to <unzip
directory>/bin and running ./RAStop.sh.
If you want to make a change to the configuration file that was generated in
step 5, the file can be manually edited using the rules outlined in the
document Agent Controller configuration files. The server must be restarted
to load changes.
Paul
news:dcu0i1$fd2$1@news.eclipse.org...
> Andi
> > Hi Andi,
Logging
> > Paul
> >>Hi Paul,
Re: Sample HyadesLoggingLog4JSample [message #25742 is a reply to message #25038] |
Fri, 05 August 2005 13:20 |
Heiner Westphal Messages: 18 Registered: July 2009 |
Andreas and Paul,
I stubled across the very same issue as Andreas did and
can add some more info:
Running the sample and manually attach to the Logging Agent
always works for me. You just have to make sure NOT to start
the HyadesLoggingLog4JSample from the Profile menu (my first
error; one of many :) .
Attaching to the Logging Agent automatically only works,
if I DISABLE profiling (uncheck
Window > Preferences... > Profiling and Logging > Enable Profiling).
Otherwise the LogView is empty (yes, I did refresh) and no
LogAgent can be seen, when trying to attach.
This is Windows XP Home with all security relevant patches to date
and TPTP 4.0.0 / eclipse 3.1 (AgentController is not running as a
service, since I feared difficulties with susp-ed and mounted volumes,
as in https://bugs.eclipse.org/bugs/show_bug.cgi?id=77831 ).
Maybe my setup is broken somehow, but since "logging only" works, I
suspect the AgentController, or some other part of TPTP is misbehaving
here, or I simply don't understand how all that TPTP-components are
meant to work together.
Hope this helps,
Heiner
P.S.: If you need some more experiments done with my setup, just ask.
Andreas Kuhn wrote:
> Hi Paul,
> level to DEBUG.
> text to attach now.
> Andi
>> Hi Andi,
>> (Window
>>> specified
>> Thanks,
>> Paul
>>> Hi,
>>> Any hints ?
>>> Thanks,
>>> Andi
[removed serverlog.log]
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #25743 is a reply to message #25741] |
Fri, 05 August 2005 14:21 |
Hi Paul,
ok, it is written in c.. 1.) Add the <unzip directory>/lib directory
to the system's LD_LIBRARY_PATH environment variable
I think for understanding the concept of the RAC this should be changed,
because for running the raserver itself it is NOT necessary to add this
to the systems LD_LIBRARY_PATH ( on linux meaning e.g. putting it in
/etc/profile, which is not an option for me, in a production environment
i would create a special user and only this user should start raserver)
The bin/RAStart.sh itself puts the lib directory in the LD_LIBRARY_PATH,
so the raserver is able to start without the system wide variable.
The problem indeed is not a RAC problem but a client application problem
- in this special case the HyadesLoggingLog4JSample application. This
one also needs the platform libraries from the lib directory (bin on
windows), but this isn't explained anywhere. Of course, if the lib is in
the systems LD_LIBRARY_PATH, the clients also will find the lib. But as
i said, for raserver itself it is not necessary and in my opinion would
be better to separate these concerns - and i think the documentation
should be changed here to clarify the dependencies.
Andi
> Hi Andi,
> Prerequisites
> export
> Notation
> configuration file.
> to load changes.
> Paul
>>Hi,
>>Andi
>>>Hi Andi,
> Logging
>>>Paul
>>>>Hi Paul,
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #25751 is a reply to message #25741] |
Fri, 05 August 2005 14:28 |
Hi again,
as an example just came to my mind:
If you install the RAC on system A following the intall guide below,
and then start your eclipse workbench on system b (which hasn't got a
RAC installed) and start the HyadesLoggingLog4JSample in this eclipse
workbench it wouldn't work, because the libraries are not found.
I think this should really be explained somewhere in the documentation.
Or maybe it is and i havn't found it ;)
Andi
> Hi Andi,
> Prerequisites
> export
> Notation
> configuration file.
> to load changes.
> Paul
>>Hi,
>>Andi
>>>Hi Andi,
> Logging
>>>Paul
>>>>Hi Paul,
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #25760 is a reply to message #25741] |
Fri, 05 August 2005 14:43 |
Me again :)
ok, last example was not a very good one, because i think somewhere
is written, the every system using TPTP should have a RAC installed.
But the point i want to clearify is that putting the libraries in the
system path is not good practice (<ironic on> maybe it is on windows
systems but not on UNIX</ironic off>.
By putting this into the install guide for the RAC, it seems this is
necessary for the RAC itself - which it isn't. It just in secret lets
all clients on the machine be able to contact the RAC and i think the
documentation should somewhere explain that.
Andi
> Hi Andi,
> Prerequisites
> export
> Notation
> configuration file.
> to load changes.
> Paul
>>Hi,
>>Andi
>>>Hi Andi,
> Logging
>>>Paul
>>>>Hi Paul,
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #25965 is a reply to message #25743] |
Tue, 09 August 2005 14:43 |
Hi Andi,
You are right to say that only the Agent Controller's lib or bin
directory needs to be accessible by the JVM (LD_LIBRARY_PATH or PATH) for
the Logging Agent to load its native library. However, this example
requires that the Agent Controller be installed, configured and running,
otherwise the client (TPTP workbench) could not communicate with the Logging
Agent. Since on some UNIX systems adding the Agent Controller's lib
directory is not feasible, I think the readme for this example should be
updated to instruct the user to set the appropriate configuration when
launching from the TPTP workbench. Please open a TPTP defect
(https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP) for this issue
under the Platform.Execution component.
Paul
news:42F375FD.8020507@arcor.de...
> Hi Paul,
> Andi
> > Hi Andi,
the
> > Prerequisites
executable
environment
> > export
should
element's
the
properly
shared
media.
> > Notation
has
> > configuration file.
accomplished by
from
generated in
restarted
> > to load changes.
> > Paul
> >>Hi,
> >>Andi
> >>>Hi Andi,
the
Common
> > Logging
> >>>Paul
> >>>>Hi Paul,
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #26006 is a reply to message #25751] |
Tue, 09 August 2005 14:45 |
Hi Andi,
This example requires that the Agent Controller be installed, configured
(Agent Controller's lib or bin
the Logging Agent to load its native library) and running, otherwise the
client (TPTP workbench) could not communicate with the Logging Agent.
Please add a request for clarification to the sample's readme in your
defect.
Paul
news:dcvt1e$bmn$1@news.eclipse.org...
> Hi again,
> Andi
> > Hi Andi,
the
> > Prerequisites
executable
environment
> > export
should
element's
the
properly
shared
media.
> > Notation
has
> > configuration file.
accomplished by
from
generated in
restarted
> > to load changes.
> > Paul
> >>Hi,
> >>Andi
> >>>Hi Andi,
the
Common
> > Logging
> >>>Paul
> >>>>Hi Paul,
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #26047 is a reply to message #25760] |
Tue, 09 August 2005 14:46 |
news:dcvtu1$ct1$1@news.eclipse.org...
> Me again :)
> Andi
> > Hi Andi,
the
> > Prerequisites
executable
environment
> > export
should
element's
the
properly
shared
media.
> > Notation
has
> > configuration file.
accomplished by
from
generated in
restarted
> > to load changes.
> > Paul
> >>Hi,
> >>Andi
> >>>Hi Andi,
the
Common
> > Logging
> >>>Paul
> >>>>Hi Paul,
Re: Sample HyadesLoggingLog4JSample [SOLVED] [message #26089 is a reply to message #25760] |
Tue, 09 August 2005 14:47 |
Hi Andi,
Since on some UNIX systems adding the Agent Controller's lib directory
is not feasible, I think the readme for this example and possible the
getting_started.html document for the Agent Controller should be updated to
instruct the user to set the appropriate configuration when launching from
the TPTP workbench. Please add a request for clarification to the readme for
the sample and Agent Controller in your defect.
Paul
> Me again :)
> Andi
> > Hi Andi,
the
> > Prerequisites
executable
environment
> > export
should
element's
the
properly
shared
media.
> > Notation
has
> > configuration file.
accomplished by
from
generated in
restarted
> > to load changes.
> > Paul
> >>Hi,
> >>Andi
> >>>Hi Andi,
the
Common
> > Logging
> >>>Paul
> >>>>Hi Paul,
Current Time: Thu Apr 25 06:47:05 GMT 2024
Powered by FUDForum. Page generated in 0.05649 seconds
