Home » Newcomers » Newcomers » Type can not be resolved!(help me!)
Type can not be resolved! [message #1419499] Mon, 08 September 2014 18:05 Go to next message
Matty widdop is currently offline Matty widdopFriend
Hello, so I've recently got into java and I'm pretty good with it so I decided to create a plugin for my server that links in with WG and factions, it all works fine but when I try to define the package right at the top of the page I get this error:
The type com.google.gson.Gson cannot be resolved. It is indirectly referenced from required .class files
I have tried to remove the JRE library and re-adding it, but no luck. the code for the class file is as follows:
package me.HexCraft;
import org.bukkit.ChatColor;
import org.bukkit.Location;
import org.bukkit.Material;
import org.bukkit.Server;
import org.bukkit.block.Block;
import org.bukkit.entity.Entity;
import org.bukkit.entity.Player;
import org.bukkit.event.Event.Result;
import org.bukkit.event.EventHandler;
import org.bukkit.event.Listener;
import org.bukkit.event.block.Action;
import org.bukkit.event.block.BlockPlaceEvent;
import org.bukkit.event.player.PlayerInteractEntityEvent;
import org.bukkit.event.player.PlayerInteractEvent;
import org.bukkit.event.player.PlayerShearEntityEvent;
import org.bukkit.inventory.ItemStack;
import org.bukkit.plugin.PluginManager;
import com.massivecraft.factions.Factions;
import com.massivecraft.factions.cmd.CmdClaim;
public class HexListener
implements Listener
private HexRestrict plugin;
public HexListener(HexRestrict plugin)
this.plugin = plugin;
plugin.getServer().getPluginManager().registerEvents(this, plugin);
@EventHandler(ignoreCancelled=false)
public void onPlayerShear(PlayerShearEntityEvent event)
if (event.getEntity().toString() == "CraftSheep") {
event.setCancelled(StopShear(event.getPlayer(), event.getEntity(), event.getEntity().getLocation()));
public void onPlayerShear(PlayerInteractEntityEvent event)
if (event.getRightClicked().toString() == "CraftSheep") {
event.setCancelled(StopShear(event.getPlayer(), event.getRightClicked(), event.getRightClicked().getLocation()));
} else {
private boolean StopShear(Player p, Entity e, Location l)
if (this.plugin.ItemUseRestrictedInsideOtherClaims.contains(new ItemInfo(p.getItemInHand().getTypeId(), null)))
Factions gp = Factions.instance;
CmdClaim claim = gp.dataStore.getClaimAt(l, true, null);
if ((!p.isOp()) &&
(claim != null))
String errorMessage = claim.allowBuild(p);
if (errorMessage != null) {
return true;
return false;
public void onPlayerInteract(PlayerInteractEvent event)
if ((event.getAction().equals(Action.RIGHT_CLICK_BLOCK)) && (event.hasItem())) {
if (this.plugin.ItemUseRestrictedInsideOtherClaims.Contains(new ItemInfo(event.getItem().getTypeId(), null)))
Player player = event.getPlayer();
Location loc = event.getClickedBlock().getLocation();
Claim claim = gp.dataStore.getClaimAt(loc, true, null);
if (!player.isOp()) {
if (claim != null)
String errorMessage = claim.allowBuild(player);
event.setUseInteractedBlock(Event.Result.DENY);
event.setUseItemInHand(Event.Result.DENY);
else
Location placedLoc = event.getClickedBlock().getRelative(event.getBlockFace(), 1).getLocation();
claim = gp.dataStore.getClaimAt(placedLoc, true, null);
if (claim != null)
return;
if (event.hasItem()) {
Location loc = event.getPlayer().getLocation();
if ((!player.isOp()) &&
(claim != null))
return;
@EventHandler(ignoreCancelled=true)
public void onPlace(BlockPlaceEvent placeEvent)
MaterialInfo blockInfo = this.plugin.BlocksRestrictedOutsideClaims.ContainsReturnName(new MaterialInfo(placeEvent.getBlock().getTypeId(), placeEvent.getBlock().getData(), null));
if (blockInfo != null)
Player player = placeEvent.getPlayer();
Block block = placeEvent.getBlock();
Claim claim = gp.dataStore.getClaimAt(block.getLocation(), true, null);
if (claim == null) {
if (!player.isOp())
placeEvent.getBlockPlaced().setType(Material.AIR);
placeEvent.setBuild(false);
placeEvent.setCancelled(true);
player.sendMessage(ChatColor.RED + "Unable to place " + blockInfo.description + " outside your claimed regions.");
return;
Re: Type can not be resolved! [message #1419504 is a reply to message #1419499] Mon, 08 September 2014 18:16 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
The message, "The type com.google.gson.Gson cannot be resolved. It is indirectly referenced from required .class files," means you need to add a library that contains the type, com.google.gson.Gson, to the project's Java Build Path. The message is literally telling you that some other class on the build path already refers to it.
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Mon, 08 September 2014 18:18]
Report message to a moderator
Re: Type can not be resolved! [message #1419528 is a reply to message #1419504] Mon, 08 September 2014 19:01 Go to previous messageGo to next message
ok, well which one is that because I didn't refer to it at all.
Re: Type can not be resolved! [message #1419555 is a reply to message #1419528] Mon, 08 September 2014 19:56 Go to previous messageGo to next message
You can't find it with Ctrl-Shift-T?
Ed Merks
Re: Type can not be resolved! [message #1419565 is a reply to message #1419555] Mon, 08 September 2014 20:17 Go to previous messageGo to next message
I've never used that xD
Re: Type can not be resolved! [message #1420137 is a reply to message #1419565] Tue, 09 September 2014 14:55 Go to previous messageGo to next message
could you just tell me which it is? xD
Re: Type can not be resolved! [message #1420159 is a reply to message #1420137] Tue, 09 September 2014 15:42 Go to previous messageGo to next message
ok, fixed it and thanks for the help. but now I am getting this error as soon as I fixed the previous: "The method allowBuild(Player) is undefined for the type Object"
the code it below:
import com.massivecraft.factions.cmd.CmdUnclaim;
implements Listener
} else {
Factions gp = Factions.i;
CmdClaim claim = gp.DataStore.getClaimAt(l, true, null);
if ((!p.isOp()) &&
(claim != null))
String errorMessage = ((Object) claim).allowBuild(p);
return true;
return false;
if (this.plugin.ItemUseRestrictedInsideOtherClaims.contains(new ItemInfo(event.getItem().getTypeId(), null)))
CmdClaim claim = gp.dataStore.getClaimAt(loc, true, null);
if (claim != null)
String errorMessage = ((Object) claim).allowBuild(player);
event.setUseInteractedBlock(event.Result.DENY);
event.setUseItemInHand(event.Result.DENY);
else
if (claim != null)
return;
CmdUnclaim claim = gp.dataStore.getClaimAt(loc, true, null);
(claim != null))
return;
CmdClaim claim = gp.dataStore.getClaimAt(block.getLocation(), true, null);
if (!player.isOp())
return;
Re: Type can not be resolved! [message #1420610 is a reply to message #1420159] Wed, 10 September 2014 08:09 Go to previous messageGo to next message
Felix Dorner is currently offline Felix DornerFriend
> the code it below:
So? Doesn't JDT exactly tell you where the error is? I bet it does. Now
you need to understand what's going on. Here's a nice read for you:
http://docs.oracle.com/javase/tutorial/java/javaOO/usingobject.html
Re: Type can not be resolved! [message #1420968 is a reply to message #1420610] Wed, 10 September 2014 19:08 Go to previous messageGo to next message
is there a video version by any chance??? xD
Re: Type can not be resolved! [message #1420983 is a reply to message #1420968] Wed, 10 September 2014 19:39 Go to previous message
I think these might be good:
http://eclipsetutorial.sourceforge.net/totalbeginnerlessons.html
Haven't seen this series, but another one by the same person, and really
liked the style.
Previous Topic:how to stop the blinking cursor in eclipse 4.4.0
Next Topic:Font size
Current Time: Wed Dec 02 07:27:10 GMT 2020
Powered by FUDForum. Page generated in 0.02735 seconds
