Home » Modeling » QVT-OML » Running QVTo in a web-based application
Running QVTo in a web-based application [message #1419179] Mon, 08 September 2014 08:00 Go to next message
Sama Elrawy is currently offline Sama ElrawyFriend
I have developed a plugin project that includes a QVTo transformation and it worked fine. However, when I tried to run the same transformation inside a java dynamic web application I got this error:
java.lang.ExceptionInInitializerError
	org.eclipse.m2m.qvt.oml.TransformationExecutor.doLoad(TransformationExecutor.java:205)
	org.eclipse.m2m.qvt.oml.TransformationExecutor.loadTransformation(TransformationExecutor.java:108)
	org.eclipse.m2m.qvt.oml.TransformationExecutor.execute(TransformationExecutor.java:137)
	saas.project.testing.doPost(testing.java:107)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
root cause
	org.eclipse.m2m.internal.qvt.oml.compiler.UnitResolverFactory$Registry$1.readFactories(UnitResolverFactory.java:66)
	org.eclipse.m2m.internal.qvt.oml.compiler.UnitResolverFactory$Registry$1.<init>(UnitResolverFactory.java:44)
	org.eclipse.m2m.internal.qvt.oml.compiler.UnitResolverFactory$Registry.<clinit>(UnitResolverFactory.java:43)
Any ideas?
Thanks in advance
Re: Running QVTo in a web-based application [message #1419235 is a reply to message #1419179] Mon, 08 September 2014 09:45 Go to previous messageGo to next message
The plugin Registry in UnitResolverFactory evaluates to null and that's why I'm getting the mentioned exception.
IExtensionRegistry pluginRegistry = Platform.getExtensionRegistry();
IExtensionPoint extensionPoint = pluginRegistry.getExtensionPoint(POINT_ID);
How can I solve this ?
Re: Running QVTo in a web-based application [message #1419273 is a reply to message #1419179] Mon, 08 September 2014 11:00 Go to previous message
It is pretty certain that you have not initialized something properly.
As always the debugger is your friend and you have a good/bad
implementation to compare so see why the bad version malfunctions, then
you will see what you failed to initialize.
Just looking at UnitResolverFactory.java:66 shows that you are
attempting to use plugin facilities in a non-plugin context.
Try Googling "QVTo standalone"
Ed Willink
On 08/09/2014 09:00, Sama Elrawy wrote:
> Hello,
> root cause
> Any ideas?
> Thanks in advance
Previous Topic:Dynamic set of input models
Next Topic:Build with Jenkins
Current Time: Wed Jul 06 05:21:12 GMT 2022
Powered by FUDForum. Page generated in 0.02373 seconds
