Home » Language IDEs » Java Development Tools (JDT) » Output dir under version control
Output dir under version control [message #251101] Tue, 29 January 2008 15:32 Go to next message
How can I make that stop? I googled far and wide but did not
find anything that helped. Adding "**/.svn/" to the build path
exclusions was an improvement but not a real fix.
-- O.L.
Re: Output dir under version control [message #251105 is a reply to message #251101] Tue, 29 January 2008 15:46 Go to previous messageGo to next message
OL,
For cvs there is a .cvsignore file in which you can add "bin" and other
build artifacts. So probably there's a .svnignore file which does that
same thing... Or maybe the problem is the copying of these files from
the source. You can use
Window->Preferences->Java->Compiler->Building->Filtered Resources to
make it not copy files from the src to the bin folder.
> -- O.L.
Re: Output dir under version control [message #251107 is a reply to message #251105] Tue, 29 January 2008 17:44 Go to previous messageGo to next message
> Or maybe the problem is the copying of these files from the source.
Yes it is. I know that because it is also copying misc. crud lying
around that is not part of the project.
Thanks! We're almost there: now it still copies the .svn directory
trees but not the files under them. Thus the output is no longer
under version control but it is still polluted by all those .svn
trees. Any idea?
-- O.L.
PS: I may sign OL but my full name is the address field ;-)
Re: Output dir under version control [message #251111 is a reply to message #251107] Tue, 29 January 2008 18:36 Go to previous message
Well if it is anything like CVS, once a file under a folder has been
checked in, the folder will always appear even when there are no files
under it.
Rich Kulp
Previous Topic:Re: Editor within swt shell
Next Topic:JDT AST analysis: performance costs or resolveBinding
Current Time: Mon May 19 15:24:46 EDT 2025
Powered by FUDForum. Page generated in 0.07055 seconds
