Home » Newcomers » Newcomers » Installing Eclipse via YaST2, repository?
Installing Eclipse via YaST2, repository? [message #1417325] |
Fri, 05 September 2014 07:25 |
Anna Discordia Messages: 1 Registered: September 2014 |
I have searched through the forum but I can't really find an answer to my question.
I'm not entirely new to Linux, however I am using openSUSE (13.1) for the first time. It's a pre-installed company PC (I don't know much about the configuration and our Linux guy has a tendency to answer questions by simply doing in seconds what I was supposed to do). Also, until now all I knew was apt.
Question: is it possible to install Eclipse through YaST (I added all the repositories YaST listed)? If so, what's the repository I need? I can't find anything but two compilers, something for debugging and a library. Oh, and an ego shooter. Yay!
I know I can use the packages from the website (those give me Java errors, but I'm sure that's a quick google search), but it bothers me that YaST can't find it since other people seem to have installed Eclipse that way. It's not the first program I can't find with YaST, either, probably just coincidence though.
It's probably a very stupid question, but I hope someone will answer it anyway.
Re: Installing Eclipse via YaST2, repository? [message #1417527 is a reply to message #1417325] |
Fri, 05 September 2014 16:46 |
Felix Dorner Messages: 295 Registered: March 2012 |
On 05/09/2014 13:27, Anna Discordia wrote:
> Hello,
> my question.
> all I knew was apt.
No idea, but usually everyone just downloads the zip from the eclipse
website. Just unzip it into your home dir and you're (usually) done.
Felix
Re: Installing Eclipse via YaST2, repository? [message #1417713 is a reply to message #1417325] |
Fri, 05 September 2014 23:10 |
On 09/05/2014 05:27 AM, Anna Discordia wrote:
> Hello,
> my question.
> all I knew was apt.
> anyway.
Unless you're running a really strange OS/configuration, never think of
not downloading Eclipse from eclipse.org. openSuSE is not a strange
OS/configuration.
Current Time: Fri Apr 19 20:01:42 GMT 2024
Powered by FUDForum. Page generated in 0.09096 seconds
