Re: Stop the code on error [message #1416606 is a reply to message #1416596] |
Fri, 17 August 2012 22:46 |
Hi Anthony,
Not sure I get your question :/ What do you mean by "when an error occurs when debugging with Koneki"?
Thanks for taking time to clarifying, hopefully I can help you then!
Benjamin
Re: Stop the code on error [message #1416608 is a reply to message #1416606] |
Sun, 26 August 2012 20:14 |
I think he wants to perform that custom function when he is debugging in the eclipse-distribution "Koneki". So: he want to run some javacode when the debugger notes an lua-related error. (Am I right?)
Re: Stop the code on error [message #1416617 is a reply to message #1416614] |
Wed, 29 August 2012 11:21 |
I just thought he would work around with the debugging-perspective.
I also develop Python and Java stuff. You can run a little bit of java when in python an error occurs (so it pauses and did not stop/exit). it runs python-code, but on an error you can Java-code(I am talking of plugin-code). I thought he meant that, but maybe ... he meant something other...
FUDForum. Page generated in 0.03383 seconds
