We need your inputs for the next release of Koneki! [message #1416504] |
Tue, 03 July 2012 16:17 |
Hi there,
Now that Koneki 0.8 is out, it is time to discuss what we should put in our next release. The plan would be to release the 0.9 version somewhere around the end of the year.
I suggest that you guys use this thread to list what you think would be great enhancements to the tools, and we will then update this http://wiki.eclipse.org/Koneki/Project_Plan/0.9 accordingly.
Of course, I know that most of the users of Koneki are using LDT, but if you are an user of the OMA-DM simulator, your inputs are also most welcome!
Re: We want your inputs for the next release of Koneki! [message #1416507 is a reply to message #1416506] |
Tue, 10 July 2012 13:02 |
Simon Bernard Messages: 345 Registered: July 2009 |
Hi uiy uiy,
Thx for your feedback.
1. You're right, we must have a more readable deliver process. We will thing about that.
2. It could be a nice improvement.
3. There are some interesting propositions. It seems our formatter could answer to your needs. Did you try it?
4. We plan to https://bugs.eclipse.org/bugs/show_bug.cgi?id=381671 system. We are focused on a smart but not complete auto-completion support, but it could have sense to complete it with dummy auto-completion. Did you try, the http://wiki.eclipse.org/Koneki/LDT/User_Guide#Execution_Environment feature ?
5. Currently, we have only one debug launch configuration : "Attach to Lua Application". It is not a very simple way to debug but it allows to support a lot of different use cases (different kind of VM, remote debugging, ...)
We plan to add other kinds of https://bugs.eclipse.org/bugs/show_bug.cgi?id=370070 to simplify some use cases (with standard eclipse shortcut Ctrl+F11 to run and F11 to debug)
FYI, The shortcut is configurable in eclipse : windows/preferences/general/keys, and you could configure if you want a prompt or not when you run an application : windows/preferences/Run-Debug/Launching.
Re: We want your inputs for the next release of Koneki! [message #1416777 is a reply to message #1416504] |
Sat, 19 January 2013 18:22 |
Hey Marc!
Looks like it's simply a matter of not forgetting to indicate which comments in your code are actually documentation comments. This is done by starting your comment with a dash. Usually it'll mean you'll have comments like --- this
or
--[[- this if you prefer block comments ... ]]
For your sample, the following should work just fine :)
-- some World of Warcraft specific stuff...
-- @module Seller
local Seller = vendor.Seller
-- some other code...
-- @function [parent=#Seller] OnInitialize
function Seller.OnInitialize(self)
end
FUDForum. Page generated in 0.04976 seconds
