Home » Eclipse Projects » Eclipse 4 » Eclipse Source Code Editor in e4 RCP
Eclipse Source Code Editor in e4 RCP [message #1416043] Thu, 04 September 2014 08:07 Go to next message
anduril elendil is currently offline anduril elendilFriend
is it possible to use the source code editor known to us from Eclipse in my own e4 RCP application? It is a pure e4 application and if possible I would really like to resign with the compatibility layer.
Currently I am using StyledText for my source code editor but it is a lot of work (syntax highlighting, code completion etc) that I think could be done much more elegant by using the Eclipse source code editor.
Thx
Re: Eclipse Source Code Editor in e4 RCP [message #1417351 is a reply to message #1416043] Fri, 05 September 2014 08:34 Go to previous messageGo to next message
Mihael Schmidt is currently offline Mihael SchmidtFriend
Member
e3 source code editor in e4 rcp? afaik the answer is ... no.
I think the best choice atm would be the SourceViewer class from JFace. It has all the hooks for the features you listed.
Re: Eclipse Source Code Editor in e4 RCP [message #1419191 is a reply to message #1417351] Mon, 08 September 2014 08:23 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
Right anything from eclipse.text and eclipse.jface.text can be used
inside e4 apps - even in a none-swt-env ;-) See
http://tomsondev.bestsolution.at/2014/08/11/efxclipse-1-0-new-features-styledtext-control-to-build-a-code-editor-framework/
Tom
Previous Topic:Customizing ToolBar
Next Topic:display order of menu items changed when migrated to Eclipse Luna
Current Time: Tue Mar 02 17:54:49 GMT 2021
Powered by FUDForum. Page generated in 0.02082 seconds
