Home » Eclipse Projects » XML Schema Definition (XSD) » Creating XSDSchema from DOM Element
Creating XSDSchema from DOM Element [message #24629] Mon, 07 July 2003 18:22 Go to next message
Originally posted by: cipher8000.yahoo.com
I am looking for a way to create the XSDSchema from an DOM Element. For
example:
Here is my schema would look like:
<definitions name="FlowSample" targetNamespace="http://samples.cxdn.com"
xmlns:tns="http://samples.cxdn.com"
xmlns="http://schemas.xmlsoap.org/wsdl/"
xmlns:s1="http://www.autoloan.com/ns/autoloan"
<types>
<schema attributeFormDefault="qualified" elementFormDefault="qualified"
targetNamespace="http://www.autoloan.com/ns/autoloan"
xmlns="http://www.w3.org/2001/XMLSchema">
<complexType name="LoanApplication">
<sequence>
<element name="SSN" type="string"/>
<element name="Email" type="string"/>
<element name="CustomerName" type="string"/>
<element name="LoanAmount" type="double"/>
<element name="CarModel" type="string"/>
<element name="CarYear" type="string"/>
<element name="CreditRating" type="int"/>
</sequence>
</complexType>
</schema>
</types>
</definitions>
I use WSDL4J's Types to extract the <schema> DOM Element and now i want to
construct
XSDSchema from that DOM Element.
Is there any util API for constructing XSDSchema from an Element?
-Muruga
Re: Creating XSDSchema from DOM Element [message #24666 is a reply to message #24629] Mon, 07 July 2003 18:37 Go to previous message
Hello,Here is a code snippet i got from XSDPrototypicalSchema, This looks
like it can load the schema from a dom element. Let me give a try! Is there
any other way of loading the schema from an Element?public XSDSchema
createSchema(org.w3c.dom.Element element) {
// Create a schema from an element.
// Test if the element is really a schema element.
if (element.getLocalName().equals("schema") &&
XSDConstants.isSchemaForSchemaNamespace(element.getNamespace URI()))
// Create the schema.
XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
// Set the element to the schema.
// This it will build the corresponding component structure.
xsdSchema.setElement(element);
return xsdSchema;
else
return null;
"Muruga" <cipher8000@yahoo.com> wrote in message
news:becdf4$5gp$1@eclipse.org...
example:
<types>
<sequence>
</sequence>
</complexType>
</schema>
</types>
</definitions>
construct
-Muruga
Re: Creating XSDSchema from DOM Element [message #574001 is a reply to message #24629] Mon, 07 July 2003 18:37 Go to previous message
return xsdSchema;
else
return null;
example:
<types>
<sequence>
</sequence>
</complexType>
</schema>
</types>
</definitions>
construct
-Muruga
Previous Topic:Creating XSDSchema from DOM Element
Next Topic:Re: getAnnotaion().getUserInfomation() returns an org.w3c.dom.Node withemty nodeValue
Current Time: Thu Oct 01 23:41:52 GMT 2020
Powered by FUDForum. Page generated in 0.02412 seconds
