Home » Modeling » TMF (Xtext) » [xtend] how to pass a function to method to use in filter
[xtend] how to pass a function to method to use in filter [message #1415244] Tue, 02 September 2014 11:55 Go to next message
Marc Schlegel is currently offline Marc SchlegelFriend
Member
I am having a little problem with the xTend syntax.
I would like to pass a function to a utility-method, which applies this function to the filter of a list.
private def void doStuff(Iterable<MyType> list, (MyType) => Boolean filterFunction)
   val result = list.filter[filterFunction] // syntax-error: cannot convert from (MyType) => (MyType) => Boolean to Function1
  .... work on result
doStuff(intputList)[e | e.isTrue] // compiles nicely
My filterFunction maps MyType to Boolean, so why cant I use it in InterableExtensions.filter?
[Updated on: Tue, 02 September 2014 11:56]
Report message to a moderator
Re: [xtend] how to pass a function to method to use in filter [message #1415251 is a reply to message #1415244] Tue, 02 September 2014 12:10 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
what about list.filter[filterFunction.apply(it)]
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: [xtend] how to pass a function to method to use in filter [message #1415252 is a reply to message #1415251] Tue, 02 September 2014 12:14 Go to previous message
Member
Christian Dietrich wrote on Tue, 02 September 2014 12:10
Yes, that works. Thanks
And as I just figured out, its even easier when using normal bracket Laughing
list.filter(filterFunction)
[Updated on: Tue, 02 September 2014 12:14]
Previous Topic:changed layout of the composite update site
Next Topic:MWE2 URI resolving
Current Time: Tue Jan 19 16:12:55 GMT 2021
Powered by FUDForum. Page generated in 0.01943 seconds
