Dynamic Help/Help Content do not open. [message #1414816] |
Mon, 01 September 2014 10:58 |
Benjamin Conklin Messages: 1 Registered: September 2014 |
Junior Member |
I try to use the "Press F2 for Focus" but it displays nothing (just hovering over words like String the box shows as empty. When I try to open up Help Content from the Help menu it seems as if it is trying to work (you can see the window opening for a split second) and then it closes again - If I try it a second time it causes the program to hang.
Thanks!
Unhandled event loop exception
java.lang.StackOverflowError
This is the first error log -
eclipse.buildId=4.4.0.I20140606-1215
java.version=1.8.0_20
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.standard.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.standard.product
org.eclipse.ui
Error
Wed Sep 03 13:34:02 EDT 2014
at org.eclipse.swt.internal.ole.win32.COM.VtblCall(Native Method)
at org.eclipse.swt.internal.ole.win32.IDispatch.Invoke(IDispatch.java:64)
at org.eclipse.swt.ole.win32.OleAutomation.invoke(OleAutomation.java:571)
at org.eclipse.swt.ole.win32.OleAutomation.invoke(OleAutomation.java:534)
at org.eclipse.swt.browser.IE.navigate(IE.java:1308)
at org.eclipse.swt.browser.IE.setUrl(IE.java:1487)
at org.eclipse.swt.browser.IE$7.handleEvent(IE.java:550)
at org.eclipse.swt.ole.win32.OleEventTable.sendEvent(OleEventTable.java:55)
at org.eclipse.swt.ole.win32.OleEventSink.notifyListener(OleEventSink.java:152)
at org.eclipse.swt.ole.win32.OleEventSink.Invoke(OleEventSink.java:120)
at org.eclipse.swt.ole.win32.OleEventSink.access$1(OleEventSink.java:97)
at org.eclipse.swt.ole.win32.OleEventSink$1.method6(OleEventSink.java:71)
at org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMObject.java:119)
at org.eclipse.swt.browser.Browser.setUrl(Browser.java:1129)
at org.eclipse.swt.browser.Browser.setUrl(Browser.java:1097)
at org.eclipse.help.ui.internal.views.BrowserPart.showURL(BrowserPart.java:371)
at org.eclipse.help.ui.internal.views.ReusableHelpPart.openInternalBrowser(ReusableHelpPart.java:1287)
at org.eclipse.help.ui.internal.views.ReusableHelpPart.showURL(ReusableHelpPart.java:1263)
at org.eclipse.help.ui.internal.views.ReusableHelpPart$12.run(ReusableHelpPart.java:1238)
at org.eclipse.help.ui.internal.views.ReusableHelpPart.showURL(ReusableHelpPart.java:1236)
at org.eclipse.help.ui.internal.views.ContextHelpPart.doOpenLink(ContextHelpPart.java:264)
at org.eclipse.help.ui.internal.views.ContextHelpPart.access$3(ContextHelpPart.java:258)
at org.eclipse.help.ui.internal.views.ContextHelpPart$2.linkActivated(ContextHelpPart.java:153)
at org.eclipse.ui.forms.widgets.FormText.activateLink(FormText.java:1552)
at org.eclipse.ui.forms.widgets.FormText.handleMouseClick(FormText.java:1355)
at org.eclipse.ui.forms.widgets.FormText.access$16(FormText.java:1326)
at org.eclipse.ui.forms.widgets.FormText$6.mouseUp(FormText.java:448)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
[Updated on: Wed, 03 September 2014 17:36] Report message to a moderator
FUDForum. Page generated in 0.07861 seconds
