Home » Newcomers » Newcomers » Trouble installing Eclipse Java IDE (Trouble installing Eclipse Java IDE for developers)
Trouble installing Eclipse Java IDE [message #1414276] Sat, 30 August 2014 21:10 Go to next message
paula chen is currently offline paula chenFriend
I downloaded the Eclipse Java IDE for developers (windows 64 bit) on this link.
https://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/luna/R/eclipse-java-luna-R-win32-x86_64.zip&mirror_id=187
When I tried to install it, this pop up window appears (view attachment). Am I missing something here? Did I choose the wrong mirror to download? Should I re-install?
Prior to this I downloaded/install both JRE 8 and JDK successfully.
Thanks in advance!
Paula
Re: Trouble installing Eclipse Java IDE [message #1414358 is a reply to message #1414276] Sun, 31 August 2014 03:28 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
You have 32-bit Java versions installed. A 64-bit Eclipse requires a 64-bit Java, and a 32-bit Eclipse requires a 32-bit Java. Perhaps you should get the 32-bit download?
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Sun, 31 August 2014 03:29]
Report message to a moderator
Previous Topic:Eclipse/Class code for calculating. Please help me.
Next Topic:Repeated Eclipse 3.8 crashes
Current Time: Thu Jun 24 01:16:20 GMT 2021
Powered by FUDForum. Page generated in 0.03047 seconds
