Home » Language IDEs » Java Development Tools (JDT) » Programatically updating the javadoc and declaration view
Programatically updating the javadoc and declaration view [message #250005] Wed, 05 December 2007 07:38 Go to next message
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enig473FD6180EA4412AB6CBD062
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: quoted-printable
Hi all,
We'd like to reuse the javadoc and declaration view to display
javadoc/java source corresponding to an element in a configuration file
in one of the projects in the workspace.
We're able to get hold of the IJavaElement and are putting in this
reflection hack to update the javadoc/declaration view with the
IJavaElement.
Is there a better way to do this ? Does my editor need to publish
something that I should be ?
* Shows the java element in view specified by viewId
public void show(final IJavaElement element, String viewId){
// get hold of the view javadoc/declaration view
AbstractInfoView infoView =3D (AbstractInfoView)
workbenchPart.getSite().getPage().findView(viewId);
// get hold of the computeInput protected method, and invoke it.
// returns the text to be set into the view.
Method computeInput =3D
AbstractInfoView.class.getDeclaredMethod("computeInput", Object.class);
computeInput.setAccessible(true);
String source =3D (String) computeInput.invoke(infoView, element);
// set the IJavaElement into the view.
Field fCurrentViewInput =3D
AbstractInfoView.class.getDeclaredField("fCurrentViewInput");
fCurrentViewInput.setAccessible(true);
fCurrentViewInput.set(infoView, element);
// set the text into the view
Method doSetInput =3D
AbstractInfoView.class.getDeclaredMethod("doSetInput", Object.class);
doSetInput.setAccessible(true);
doSetInput.invoke(infoView, source);
Ketan Padegaonkar
I blog... therefore I am... http://ketan.padegaonkar.name/
http://swtbot.org
Slackware is not for you. You do not possess the Tao.
-- +Chiron+
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHVpvZ50uB2zvyE8MRAqR6AJ9Zo77RX/znvUeP83+UaawbTj3Q6wCf TnBu
G/g/Gua4MzvOnPcv8yS5XEI=
=N1jw
-----END PGP SIGNATURE-----
--------------enig473FD6180EA4412AB6CBD062--
Re: Programatically updating the javadoc and declaration view [message #250156 is a reply to message #250005] Tue, 11 December 2007 10:20 Go to previous messageGo to next message
Ketan Padegaonkar wrote:
>Hi all,
>IJavaElement.
Not with 3.3.x. Stating with 3.4 M4 you'll see:
org.eclipse.jdt.internal.ui.infoviews.AbstractInfoView.setIn put(IJavaElement)
Dani
> AbstractInfoView infoView = (AbstractInfoView)
> String source = (String) computeInput.invoke(infoView, element);
>AbstractInfoView.class.getDeclaredField("fCurrentViewInput ");
> Method doSetInput =
>Cheers,
>Ketan Padegaonkar
>http://swtbot.org
> -- +Chiron+
Re: Programatically updating the javadoc and declaration view [message #250168 is a reply to message #250156] Wed, 12 December 2007 07:03 Go to previous message
--------------enigF4E1489BB37760B1D179E563
>=20
>> Hi all,
>> javadoc/java source corresponding to an element in a configuration fil=
e
>> IJavaElement.
>> =20
> org.eclipse.jdt.internal.ui.infoviews.AbstractInfoView.setIn put(IJavaEl=
ement)
Daniel, thanks for the heads up.
>=20
>=20
> Dani
>> Cheers,
>> Ketan Padegaonkar
>> http://swtbot.org
>> -- +Chiron+
--=20
Ketan Padegaonkar
http://swtbot.org
-- +Chiron+
iD8DBQFHX83450uB2zvyE8MRAjuoAJ9016RKXq/kXEF0AOEEnAGNB4FVrgCe LeCA
xPXdsknUDFXklQADGlsG50Y=
=G7K9
--------------enigF4E1489BB37760B1D179E563--
Previous Topic:Programmatically adding projects to the standard source lookup
Next Topic:JNI in Eclipse: help getting started
Current Time: Tue May 13 19:45:52 EDT 2025
Powered by FUDForum. Page generated in 0.04204 seconds
