Home » Newcomers » Newcomers » Eclipse/Class code for calculating. Please help me.
icon9.gif  Eclipse/Class code for calculating. Please help me. [message #1413847] Fri, 29 August 2014 11:16 Go to next message
Embarrassed Embarrassed Embarrassed
I'm new to eclipse and i resently started to work with it in school.
I got an assignment to write a code that will work as a simple calculator.
Example when i start the program it asks for a number from -2.000.000 and 2.000.000
lets say i write down 7
then it says good, now write another number.
i write for an example 2.
Now what the program does is answering the result of 2+7=9
i want to learn about dividing
subtraction
multiplikation
and as i create new project i use class and i dont want it to open a very nice calculator. i want everything to go into the console.
Please dont do bad commenting. i am trying as hard as i can.
Re: Eclipse/Class code for calculating. Please help me. [message #1413955 is a reply to message #1413847] Fri, 29 August 2014 17:22 Go to previous message
On 08/29/2014 09:29 AM, Masis Mansour wrote:
> :blush: :blush: :blush:
> subtraction
> multiplikation
You're also brand new to Java.
These are Java and general programming questions. You should try another
forum for those. I'd suggest javaranch.com and/or stackoverflow.com.
Previous Topic:External Tool Issue
Next Topic:Trouble installing Eclipse Java IDE
Current Time: Sun Nov 02 02:49:43 EST 2025
Powered by FUDForum. Page generated in 0.07368 seconds
