Home » Newcomers » Newcomers » Error Trying to Run JUnit Tests(An internal error occurred during: "class name" . java.lang.NullPointerException)
Error Trying to Run JUnit Tests [message #1413530] Thu, 28 August 2014 19:38 Go to next message
Matthew Clark is currently offline Matthew ClarkFriend
Good Afternoon everyone. I am just starting out with JUnit testing for an application we are developing and have been following some online training.
When I created a basic unit test and click on run, I am getting the following error:
An internal error occurred during: "Launching HelloJUnit".
I am not sure what the issue could be and I was looking to see if there were others that have had this issue, to see what they did to solve it.
Also not sure if I have the right versions installed to use JUnit.
Eclipse.org - Eclipse Platform - Version 4.2.1.v20130118
Eclipse.org - Eclipse RCP - Version 4.2.2.v20130129
Eclipse.org - Help System Base - Version 1.4.1.v20120912
Android Developer Tools - ADT Package - Version 23.0.2.1259578
Matthew Clark
Software Engineer
Automation Engineer
Re: Error Trying to Run JUnit Tests [message #1413683 is a reply to message #1413530] Fri, 29 August 2014 06:51 Go to previous messageGo to next message
priya sahoo is currently offline priya sahooFriend
Please explain a bit more.
Gyan
Re: Error Trying to Run JUnit Tests [message #1413811 is a reply to message #1413683] Fri, 29 August 2014 13:29 Go to previous messageGo to next message
I have created a project in Eclipse and have added in some tests. When I attempt to run/debug the tests using Run As -> JUnit tests, I receive an error that states :
The HelloJUnit is just a sample test that I was working on in a training.
I have tried to include the different versions/settings that I could find in Eclipse that might help someone figure out if I don't have something configured properly. It is attempting to use JUnit 4, JRS System Library [JavaSE-1.7]
Matthew Clark
Software Engineer
Automation Engineer
Re: Error Trying to Run JUnit Tests [message #1413952 is a reply to message #1413530] Fri, 29 August 2014 21:19 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> training.
> following error:
It would be easier to guess what went wrong with a bit more of the NPE
stack trace.
Re: Error Trying to Run JUnit Tests [message #1415403 is a reply to message #1413952] Tue, 02 September 2014 17:56 Go to previous messageGo to next message
I believe that I have figured out my issue. I was using a workspace that was incompatible with what I was trying to do. Made a few changes and now I am able to run the unit tests again.
Matthew Clark
Software Engineer
Automation Engineer
Re: Error Trying to Run JUnit Tests [message #1415734 is a reply to message #1415403] Wed, 03 September 2014 13:41 Go to previous messageGo to next message
Shmuel Weiss is currently offline Shmuel WeissFriend
I have the same issue, please I have spent the whole day trying to fix this issue.
I have a clean adt-bundle-windows-x86_64-20140702 with ECLIPSE JUNO installed on my laptop and I got this error by trying to run a JUnit Test.
What do you mean by a not compatible workspace ? please let me know what you did in order to fix the issue.
thanks.
Re: Error Trying to Run JUnit Tests [message #1417339 is a reply to message #1415403] Fri, 05 September 2014 08:01 Go to previous message
Gaurav Jindal is currently offline Gaurav JindalFriend
Hi Matthew I am facing the same problem, Please explain what you mean by incompatible workspace. Thanks !
Previous Topic:MySQL JDBC Driver Not Found From build.xml
Next Topic:Deploy test resource to Tomcat Server
Current Time: Wed Jan 27 12:26:01 GMT 2021
Powered by FUDForum. Page generated in 0.03256 seconds
