Error Trying to Run JUnit Tests [message #1413530] |
Thu, 28 August 2014 19:38  |
Good Afternoon everyone. I am just starting out with JUnit testing for an application we are developing and have been following some online training.
When I created a basic unit test and click on run, I am getting the following error:
An internal error occurred during: "Launching HelloJUnit".
I am not sure what the issue could be and I was looking to see if there were others that have had this issue, to see what they did to solve it.
Also not sure if I have the right versions installed to use JUnit.
Eclipse.org - Eclipse Platform - Version 4.2.1.v20130118
Eclipse.org - Eclipse RCP - Version 4.2.2.v20130129
Eclipse.org - Help System Base - Version 1.4.1.v20120912
Android Developer Tools - ADT Package - Version 23.0.2.1259578
Matthew Clark
Software Engineer
Automation Engineer
Re: Error Trying to Run JUnit Tests [message #1413811 is a reply to message #1413683] |
Fri, 29 August 2014 13:29   |
I have created a project in Eclipse and have added in some tests. When I attempt to run/debug the tests using Run As -> JUnit tests, I receive an error that states :
The HelloJUnit is just a sample test that I was working on in a training.
I have tried to include the different versions/settings that I could find in Eclipse that might help someone figure out if I don't have something configured properly. It is attempting to use JUnit 4, JRS System Library [JavaSE-1.7]
Matthew Clark
Software Engineer
Automation Engineer
Re: Error Trying to Run JUnit Tests [message #1413952 is a reply to message #1413530] |
Fri, 29 August 2014 21:19   |
> training.
> following error:
It would be easier to guess what went wrong with a bit more of the NPE
stack trace.
Re: Error Trying to Run JUnit Tests [message #1415403 is a reply to message #1413952] |
Tue, 02 September 2014 17:56   |
I believe that I have figured out my issue. I was using a workspace that was incompatible with what I was trying to do. Made a few changes and now I am able to run the unit tests again.
Matthew Clark
Software Engineer
Automation Engineer
FUDForum. Page generated in 0.03278 seconds
