Home » Eclipse Projects » scout » TablePageData and SearchForm
TablePageData and SearchForm [message #1413318] Thu, 28 August 2014 09:10 Go to next message
Nils Israel is currently offline Nils IsraelFriend
Member
I am testing the cool new feature TablePageData. Without a searchform it is working fine. But let's say there is a TablePage with 3 Columns: IDColumn, NameColumn and TownColumn.
The corresponding SearchForm has two fields: NameField and TownField.
Without TablePageData the relevant lines in the OutlineService are:
public Object[][] getUserData(UserSearchForm formData){
	StringBuilder statement = new StringBuilder();
	statement.append(""
	+"SELECT "
	+"	id, "
	+"	name, "
	+"	town "
	+"FROM "
	+"	users "
	+"WHERE 1=1 ");
	if (!StringUtility.isNullOrEmpty(formData.getName().getValue())){
		statement.append(" AND name like :name ");
	if (!StringUtility.isNullOrEmpty(formData.getTown().getValue())){
		statement.append(" AND town like :town ");
	return SQL.select(statement.toString(), formData);
With the TablePageData the lines are:
public UserTablePageData getUserData(UserSearchForm formData){
	UserTablePageData = new UserTablePageData();
	statement.append(""
	+"SELECT "
	+"	id, "
	+"	name, "
	+"	town "
	+"FROM "
	+"	users "
	+"WHERE 1=1 ");
	statement.append(""
	+"INTO "
	+"	:{id} "
	+"	:{name}, "
	+"	:{town}");
	SQL.selectInto(statement.toString(), formData, tablePageData);
	return tablePageData;
But now I get a ProcessingException:
expected a single value for ":{name}" but got multiple values.
Obviously the problem occurs because the field in the SearchForm an the column in the TablePageData have the same name.
It gets strange when I change the order of the bind bases:
SQL.selectInto(statement.toString(), tablePageData, formData);
I get all table rows and no error message if I leave the search fields empty. And so I thought this may be a workaround. But if I fill the name or the town field with a search string that should lead to some rows I get an empty (no rows) TablePageData. The strange thing is, that the debug log doesn't even show a sql query. So there is an empty TablePageData and no error message indicating that something has gone wrong.
Is there something I can do without changing the column or the search field names?
Kind regards,
Nils
Re: TablePageData and SearchForm [message #1413390 is a reply to message #1413318] Thu, 28 August 2014 12:24 Go to previous messageGo to next message
Jeremie Bresson is currently offline Jeremie BressonFriend
This is a really interesting point. Thanks for your detailed description.
Quick/untested idea:
I think you can provide a name to the tableData with NVPair (class org.eclipse.scout.commons.holders.NVPair):
SQL.selectInto(statement.toString(), formData, new NVPair("table", tablePageData));
And then in your bindings:
INTO
   :{table.id}
   :{table.name},
   :{table.town}
If this does'nt work, fell free to tell me. We need to find a solution for your problem.
___
Edit 08.09.2014:
By the way, I have written "untested", but I wrote the exact same code for the MiniCRM example on GitHub in october 2013. See StandardOutlineService.
[Updated on: Mon, 08 September 2014 18:42]
Report message to a moderator
Re: TablePageData and SearchForm [message #1413417 is a reply to message #1413390] Thu, 28 August 2014 13:17 Go to previous messageGo to next message
Dennis Geesen is currently offline Dennis GeesenFriend
Member
Sometime ago I was looking into the parser for the SQL binding and found a special keyword to mark output tokens: [OUT]
so, another approach would be something like:
INTO :[OUT]name
However, I've never tested that option before. So, maybe one of the scout team knows more about it?!
Re: TablePageData and SearchForm [message #1413427 is a reply to message #1413390] Thu, 28 August 2014 13:41 Go to previous messageGo to next message
Member
Hi Jeremie and Dennis,
thanks for your help.
I tried both and the approach from Jeremie is working. So I added a note to the wiki (Concepts,New and Noteworthy).
Kind regards,
Nils
Re: TablePageData and SearchForm [message #1413466 is a reply to message #1413427] Thu, 28 August 2014 15:43 Go to previous message
Notice that in my example the name of the bind is absolutely free. To avoid the confusion with the OUT mentioned by Dennis, I have changed it to table.
Thanks a lot for the update of the documentation. It is nice to see contribution in this area.
This problem of 2 binds having conflicting names occurs in your case with a formData and a tablePageData, but I could imagine a lot of other situation where it could be a problem.
Example: reading from 2 formData in the same query select query for example.
PersonFormData with a property "id"
CompanyFormData with a property also called "id"
Select ... from ... where COMPANY_NR = :id /*from person formData*/ and PERSON_NR = :id /*from company formData*/
You should use the same trick:
SQL.select(query, new NVPair("company", companyFormData ), new NVPair("person", personFormData))
and in the query:
Select ... from ... where COMPANY_NR = :company.id and PERSON_NR = :person.id /*from company formData*/
I think the trick with 2 NVPair will also work for those cases.
I have referenced this forum thread as "TODO" in Sql Service > advanced binding
Previous Topic:Exported Scout application not working
Next Topic:Exclude client during server export
Current Time: Wed Jun 19 07:16:09 GMT 2019
Powered by FUDForum. Page generated in 0.02033 seconds
