Home » Modeling » TMF (Xtext) » Headless Xcore generation with edit plug-in
Headless Xcore generation with edit plug-in [message #1413021] Wed, 27 August 2014 15:24 Go to next message
Axel Guckelsberger is currently offline Axel GuckelsbergerFriend
Hi all,
I am trying to get Xcore generation working headlessly using a mwe2
workflow.
The xcore file has the following package annotation:
@GenModel(
    modelDirectory="org.example.mydsl/emf-gen",
    editPluginID="org.example.mydsl.edit",
    editDirectory="org.example.mydsl.edit/src-gen",
    forceOverwrite="true",
    updateClasspath="false",
    complianceLevel="5.0",
    operationReflection="false",
    runtimePlatform="RCP")
Inside the IDE everything works as expected with this.
The mwe2 workflow looks as follows:
var projectName = "org.example.mydsl"
var runtimeProject = "../${projectName}"
Workflow {
    bean = StandaloneSetup {
        scanClassPath = true
        platformUri = "${runtimeProject}/.."
        registerGenModelFile =
"platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
    component = org.eclipse.emf.mwe.utils.DirectoryCleaner {
        directory = 'emf-gen'
    component = de.itemis.xcore2java.XcoreReader {
        register = org.eclipse.emf.ecore.xcore.XcoreStandaloneSetup {}
        path = 'model'
        slot = 'model'
    component = org.eclipse.xtext.generator.GeneratorComponent {
        slot = 'model'
        outlet = {
            path = 'emf-gen'
While the actual meta classes are generated properly in Jenkins the edit
plug-in's classes seem to be ignored (or generated to somewhere unexpected).
Any idea what needs to be done here? Is a second outlet required maybe?
TIA,
Axel
Re: Headless Xcore generation with edit plug-in [message #1416096 is a reply to message #1413021] Thu, 04 September 2014 09:59 Go to previous message
Hi again,
as a workaround I just added the generated edit classes to Git temporarily.
If anybody knows a way to generate them headlessly some hints about how to
achieve that would be greatly appreciated though.
Axel
Previous Topic:XTEXT Features with fixed length
Next Topic:Errors while running Xtext Junit from command line
Current Time: Fri Nov 27 20:51:48 GMT 2020
Powered by FUDForum. Page generated in 0.02033 seconds
