Marker id nnn not found [message #1412910] |
Wed, 27 August 2014 10:43 |
I see the exception below from time to time when using our Xtext based editor (Geppetto). Our own code is not on the trace and so far I've not found the cause. Does anyone have a clue as to why this is happening?
I'm using Xtext 2.6.2.
!MESSAGE org.eclipse.xtext.ui.editor.validation.MarkerIssueProcessor - Could not create marker.
!STACK 0
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:121)
at org.eclipse.xtext.ui.editor.validation.MarkerIssueProcessor.processIssues(MarkerIssueProcessor.java:58)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:67)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.core.internal.resources.ResourceException: Marker id 219 not found.
at org.eclipse.core.internal.resources.Marker.checkInfo(Marker.java:57)
at org.eclipse.core.internal.resources.Marker.setAttribute(Marker.java:237)
at org.eclipse.xtext.ui.editor.validation.MarkerCreator.setMarkerAttributes(MarkerCreator.java:45)
at org.eclipse.xtext.ui.editor.validation.MarkerCreator.createMarker(MarkerCreator.java:31)
at org.eclipse.xtext.ui.editor.validation.AddMarkersOperation.execute(AddMarkersOperation.java:106)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2313)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
... 3 more
Root exception:
Re: Marker id nnn not found [message #1415440 is a reply to message #1412910] |
Tue, 02 September 2014 19:56 |
> !STACK 0
> at
> at
> at
> id 219 not found.
> at
> at
> at
> at
> at
> at
> at
> ... 3 more
> Root exception:
> found.
> at
> at
> at
> at
> at
> at
> at
> at
> at
Hi Thomas
I sometimes see the "Marker id nnn not found" in the Error Log View in
the second eclipse instance when many dependencies change in the
development instance (i.e., the target platform of the second instance
has many changes).
Could it be due to some missing synchronizations during the rebuild?
In my case, this is not blocking though...
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
FUDForum. Page generated in 0.02841 seconds
