Home » Modeling » TMF (Xtext) » Code Formatter and comments.
Code Formatter and comments. [message #1412849] Wed, 27 August 2014 08:17 Go to next message
Markus Duft is currently offline Markus DuftFriend
Hey. I have a slight problem with code formatting in my DSL. Assume this file contents:
 * comment
persistent XX {
	 * asd
	data-category XX;
			 * more comment
	attribute xx : common.BOOLEAN {
		property label "Something";
running the code formatter with this config:
	override protected void configureFormatting(FormattingConfig c) {
		c.setAutoLinewrap(120);
		for (pair : ga.findKeywordPairs("{", "}")) {
			c.setNoLinewrap.before(pair.first);
			c.setLinewrap(1, 1, 1).after(pair.first);
			c.setLinewrap(1, 1, 2).before(pair.second);
			c.setLinewrap(1, 1, 2).after(pair.second);
			c.setIndentationIncrement.after(pair.first);
			c.setIndentationDecrement.before(pair.second);
		for (kw : ga.findKeywords(";")) {
			c.setLinewrap(1, 1, 2).after(kw);
			c.setNoSpace.before(kw);
		c.setNoLinewrap.before(ga.connectionAccess.toKeyword_4);
		// It's usually a good idea to activate the following three statements.
		// They will add and preserve newlines around comments
		c.setLinewrap(0, 1, 2).before(SL_COMMENTRule)
		c.setLinewrap(0, 1, 2).before(ML_COMMENTRule)
		c.setLinewrap(0, 1, 1).after(ML_COMMENTRule)
yields this weird formatted comments. what am i doing wrong?? xtext version is 2.6.0.
 * comment
persistent XX {
	 * asd
	data-category XX;
			 * more comment
Any hints? Will I have to write my own formatter without help from the declarative one?
Thanks!
Re: Code Formatter and comments. [message #1412870 is a reply to message #1412849] Wed, 27 August 2014 09:03 Go to previous messageGo to next message
Thomas Fritsch is currently offline Thomas FritschFriend
Looks very much like https://bugs.eclipse.org/bugs/show_bug.cgi?id=313133
Re: Code Formatter and comments. [message #1412905 is a reply to message #1412870] Wed, 27 August 2014 10:34 Go to previous messageGo to next message
Hey, thanks for the pointer, didn't find that one o.O
Will try the workaround, as I really need this working (I'm implementing format on save, so this must work then Wink)
Re: Code Formatter and comments. [message #1412956 is a reply to message #1412905] Wed, 27 August 2014 12:26 Go to previous message
Sadly this does not help at all... Neutral any hints on what I could try?
Previous Topic:References across files
Next Topic:right place to add save actions?
Current Time: Sat Apr 20 01:24:09 GMT 2024
Powered by FUDForum. Page generated in 0.02961 seconds
