Re: the automatically generated makefile [message #1413306 is a reply to message #1413258] |
Thu, 28 August 2014 08:47 |
Sequoia Tree Messages: 28 Registered: August 2014 |
>>I'm a bit slow - it seems that you are attempting to cut corners compiling a Qt application. The Qt qmake creates the necessary makefiles.
>>Eclipse has a Qt support module which is installable using the Luna site.
If cutting corners means trying to find out how something works then you are right on the button.
I want to learn how to use eclipse and one way is to transform my monstrous SpaceFlight project from Java to C++. For that I need to learn how Eclipse does GUI. And I am starting with Qt library QWidgets. True, I could use the Qt Creator IDE to do this, but I would like to finally understand this behemoth Eclipse.
If this Qt Support Module really exists, possibly you could put up a link.
[Updated on: Thu, 28 August 2014 08:58] Report message to a moderator
Re: the automatically generated makefile [message #1413809 is a reply to message #1413306] |
Fri, 29 August 2014 13:22 |
Tauno Voipio Messages: 743 Registered: August 2014 |
David Hall wrote on Thu, 28 August 2014 11:47
Open your Luna, Help -> Install New Software, select Luna site (download.eclipse.org/releases/luna), Programming Languages -> C/C++ Qt Support.
Tauno Voipio
FUDForum. Page generated in 0.05759 seconds
