I can't import a project [message #1411917] |
Sun, 24 August 2014 21:27 |
Eclipse Guest Messages: 93 Registered: February 2013 Location: Vienna |
Member |
I have found a source code that I want to look a little extra on. But I can not get it to open with Eclipse. I am 100% sure that I am doing itright yetit will not work.
I'm certain the steps I am doing is correct, here is how i do it.
1: File
2: Import
3: Root Directory / Browse
4: Then I choose only the file I downloaded?
Then when you click Finish, nothing will happen at all.
Here is the code: http://www.sourcecodester.com/android/7491/chart-application-android.html
Does anyone know where the problem is? If you have any other questions then just ask.
Thanks in advance.
[Updated on: Sun, 24 August 2014 21:30] Report message to a moderator
FUDForum. Page generated in 5.08868 seconds
