Home » Eclipse Projects » e(fx)clipse » I have installed the most recent e(fx)clipse AinO packages and it gives me this errors
icon9.gif  I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1410778] Thu, 21 August 2014 15:37 Go to next message
Yongshin Kim is currently offline Yongshin KimFriend
!SESSION 2014-08-21 14:48:27.460 -----------------------------------------------
eclipse.buildId=4.4.0.I20140606-1215
java.version=1.8.0_20
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=ko_KR
Command-line arguments:  -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.fx.ide.java6 4 0 2014-08-21 14:48:39.440
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.fx.ide.java6 [218]
  Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version>=1.3)(!(version>=1.8)))"
	at org.eclipse.osgi.container.Module.start(Module.java:434)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.e4.ui.workbench 1 0 2014-08-21 14:48:59.044
!MESSAGE Nothing to merge for "platform:/plugin/org.eclipse.e4.tools.emf.ui/fragment.e4xmi"
!ENTRY org.eclipse.e4.ui.workbench 1 0 2014-08-21 14:48:59.050
What should I do? Sad
[Updated on: Fri, 22 August 2014 17:00]
Report message to a moderator
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1410781 is a reply to message #1410778] Thu, 21 August 2014 15:42 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Is something not working?
The resolve error is expected and *has to* happen because we only want
the "org.eclipse.fx.ide.java6" to resolve if you happen to run on JDK7
or even JDK6.
Tom
> me this errors
> java.vendor=Oracle Corporation
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.jface 4 0 2014-08-21 14:49:09.601
> !MESSAGE Unable to resolve plug-in
> "platform:/plugin/org.eclipse.mylyn.tasks.ui/icons/eview16/task-list.gif".
> !STACK 0
> java.io.IOException: Unable to resolve plug-in
> at
> org.eclipse.core.internal.runtime.PlatformURLPluginConnection.parse(PlatformURLPluginConnection.java:64)
> at
> org.eclipse.core.internal.runtime.PlatformURLPluginConnection.resolve(PlatformURLPluginConnection.java:75)
> at
> org.eclipse.core.internal.boot.PlatformURLHandler.openConnection(PlatformURLHandler.java:67)
> at
> org.eclipse.osgi.internal.url.URLStreamHandlerProxy.openConnection(URLStreamHandlerProxy.java:114)
> at java.net.URL.openConnection(URL.java:972)
> at
> org.eclipse.core.internal.runtime.PlatformURLConverter.toFileURL(PlatformURLConverter.java:33)
> at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.java:206)
> at
> org.eclipse.jface.resource.URLImageDescriptor.getFilePath(URLImageDescriptor.java:141)
> at
> org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:162)
> at
> org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:230)
> at
> org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:208)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImageFromURI(SWTPartRenderer.java:221)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImage(SWTPartRenderer.java:233)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.createTab(StackRenderer.java:829)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.processContents(LazyStackRenderer.java:134)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:68)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:185)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
> at
> at
> at
> at
> at
> at
> org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:664)
> at
> at
> at
> at
> at
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1078)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
> at
> org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
> at
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:483)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
> !SESSION 2014-08-22 00:29:40.470
> !ENTRY org.eclipse.fx.ide.java6 4 0 2014-08-22 00:29:43.017
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.e4.ui.workbench 1 0 2014-08-22 00:29:47.574
> !ENTRY org.eclipse.e4.ui.workbench 1 0 2014-08-22 00:29:47.581
> !ENTRY org.eclipse.jface 4 0 2014-08-22 00:29:56.752
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> What should I do? :(
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1410791 is a reply to message #1410781] Thu, 21 August 2014 16:13 Go to previous messageGo to next message
index.php/fa/18910/0/
The task list window is not working Sad
By the way, I am using oracle java 1.8.0.20(verified with java -version) and Ubuntu 64bit.
  • Attachment: error.jpg
    (Size: 29.69KB, Downloaded 9870 times)
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1410848 is a reply to message #1410791] Thu, 21 August 2014 19:44 Go to previous messageGo to next message
Well you don't have Mylyn installed so there's no suprise it does not
open. You need to post install Mylyn into the All-In-One-Download.
Tom
On 21.08.14 18:13, Yongshin Kim wrote:
> The task list window is not working :(
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1410953 is a reply to message #1410848] Fri, 22 August 2014 03:15 Go to previous messageGo to next message
Oh, thanks, I installed Mylyn. and It works now Smile
I think unother error comes from missing emf tool, I'll try to install that as well.
But is there anything I can do to deal with "Could not resolve module:> org.eclipse.fx.ide.java6" error?
You told me that it is normal if I use JDK6 or 7, but I think mine uses Oracle java8 which I confirmed with 'java -version'.
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1410995 is a reply to message #1410953] Fri, 22 August 2014 06:13 Go to previous messageGo to next message
On 22.08.14 05:15, Yongshin Kim wrote:
> Oh, thanks, I installed Mylyn. and It works now :)
> that as well.
It's the opposite. If you run on java8 the bundle does not resolve, if
you would run on jdk6/7 it would resolve and bring up a message box
telling you that e(fx)clipse is disabled because it requires java8.
Tom
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411196 is a reply to message #1410995] Fri, 22 August 2014 16:33 Go to previous messageGo to next message
Thomas Schindl wrote on Fri, 22 August 2014 02:13
On 22.08.14 05:15,
Tom
I see. So I'm good Smile
But is there a way to suppress that warning? It is kinda annoying to see the error msg everytime I start the e(fx)clipse.
Yongshin
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411223 is a reply to message #1411196] Fri, 22 August 2014 18:24 Go to previous messageGo to next message
Not really - we could in future make it a single feature so that you can
uninstall it easily.
Tom
>> On 22.08.14 05:15, It's the opposite. If you run on java8 the bundle
>> Tom
> I see. So I'm good :)
> Yongshin
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411381 is a reply to message #1411223] Sat, 23 August 2014 06:04 Go to previous messageGo to next message
Thomas Schindl wrote on Fri, 22 August 2014 14:24
Tom
OK. I'll be patient and look forward for the new revision.
And one last question (Hope so Very Happy)
What module should I install to deal with
"platform:/plugin/org.eclipse.e4.tools.emf.ui/fragment.e4xmi" thing?
Thanks Smile
Seid umschlungen Millionen! Diesen Kuss der ganzen Welt! -Beethoven-
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411412 is a reply to message #1411381] Sat, 23 August 2014 08:10 Go to previous messageGo to next message
the e4 tooling should already be installed with the all-in-one package.
Tom
>> Tom
> And one last question (Hope so :d)
> Thanks :)
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411494 is a reply to message #1411412] Sat, 23 August 2014 13:50 Go to previous messageGo to next message
Thomas Schindl wrote on Sat, 23 August 2014 04:10
Tom
I do indeed located fragment.e4xmi at "org.eclipse.e4.tools.emf.ui_0.12.0.v20140728-1808.jar" file at the plug-ins folder.
It has a lot of elements nodes in it. Should I test all the elements nodes by manually erasing them one by one and see what is causing the error msg?
Yongshin
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1419852 is a reply to message #1410995] Tue, 09 September 2014 07:14 Go to previous messageGo to next message
> that as well.
Tom
May I suggest (IF POSSIBLE) changing the message and type into something less alarming then? Like a "You're properly using Java 8" warning.
From an user PoV if any other error happens and you just see "FrameworkEvent ERROR" you might think it could be one of the reasons and would spend some time checking it.
And great job, btw.
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1419857 is a reply to message #1419852] Tue, 09 September 2014 07:18 Go to previous messageGo to next message
>> > that as well.
>> module:>
>> Tom
> And great job, btw.
I can not change this message it's from the Equinox-Resolver, we could
change to resolve always and do the checks once we are loaded. File a
bug and we'll try to look into this.
Tom
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1678799 is a reply to message #1419857] Mon, 16 March 2015 10:44 Go to previous message
Thomas Schindl wrote on Tue, 09 September 2014 09:18
On 09.09.14 09:14
Tom
I created a bugzilla for the BundleException that occurs when using Java 8: https://bugs.eclipse.org/bugs/show_bug.cgi?id=462212
Previous Topic:Running OSGi Console
Next Topic:Does the efxclipse logger façade honour configuration files... ?
Current Time: Fri Feb 07 15:49:41 GMT 2025
Powered by FUDForum. Page generated in 0.04803 seconds
