Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1410781 is a reply to message #1410778] |
Thu, 21 August 2014 15:42   |
Is something not working?
The resolve error is expected and *has to* happen because we only want
the "org.eclipse.fx.ide.java6" to resolve if you happen to run on JDK7
or even JDK6.
Tom
> me this errors
> !SESSION 2014-08-21 14:48:27.460
> eclipse.buildId=4.4.0.I20140606-1215
> java.version=1.8.0_20
> java.vendor=Oracle Corporation
> BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=ko_KR
> Command-line arguments: -os linux -ws gtk -arch x86_64
> !ENTRY org.eclipse.fx.ide.java6 4 0 2014-08-21 14:48:39.440
> !MESSAGE FrameworkEvent ERROR
> !STACK 0
> org.osgi.framework.BundleException: Could not resolve module:
> org.eclipse.fx.ide.java6 [218]
> Unresolved requirement: Require-Capability: osgi.ee;
> filter:="(&(osgi.ee=JavaSE)(version>=1.3)(!(version>=1.8)))"
> at org.eclipse.osgi.container.Module.start(Module.java:434)
> at
> org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
> at
> org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
> at
> org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
> at
> org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
> at
> org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
> !ENTRY org.eclipse.e4.ui.workbench 1 0 2014-08-21 14:48:59.044
> !MESSAGE Nothing to merge for
> "platform:/plugin/org.eclipse.e4.tools.emf.ui/fragment.e4xmi"
> !ENTRY org.eclipse.e4.ui.workbench 1 0 2014-08-21 14:48:59.050
> !ENTRY org.eclipse.jface 4 0 2014-08-21 14:49:09.601
> !MESSAGE Unable to resolve plug-in
> "platform:/plugin/org.eclipse.mylyn.tasks.ui/icons/eview16/task-list.gif".
> !STACK 0
> java.io.IOException: Unable to resolve plug-in
> at
> org.eclipse.core.internal.runtime.PlatformURLPluginConnection.parse(PlatformURLPluginConnection.java:64)
> at
> org.eclipse.core.internal.runtime.PlatformURLPluginConnection.resolve(PlatformURLPluginConnection.java:75)
> at
> org.eclipse.core.internal.boot.PlatformURLHandler.openConnection(PlatformURLHandler.java:67)
> at
> org.eclipse.osgi.internal.url.URLStreamHandlerProxy.openConnection(URLStreamHandlerProxy.java:114)
> at java.net.URL.openConnection(URL.java:972)
> at
> org.eclipse.core.internal.runtime.PlatformURLConverter.toFileURL(PlatformURLConverter.java:33)
> at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.java:206)
> at
> org.eclipse.jface.resource.URLImageDescriptor.getFilePath(URLImageDescriptor.java:141)
> at
> org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:162)
> at
> org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:230)
> at
> org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:208)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImageFromURI(SWTPartRenderer.java:221)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImage(SWTPartRenderer.java:233)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.createTab(StackRenderer.java:829)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.processContents(LazyStackRenderer.java:134)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:68)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:185)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
> at
> at
> at
> at
> at
> at
> org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:664)
> at
> at
> at
> at
> at
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1078)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
> at
> org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
> at
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:483)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
> !SESSION 2014-08-22 00:29:40.470
> !ENTRY org.eclipse.fx.ide.java6 4 0 2014-08-22 00:29:43.017
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.e4.ui.workbench 1 0 2014-08-22 00:29:47.574
> !ENTRY org.eclipse.e4.ui.workbench 1 0 2014-08-22 00:29:47.581
> !ENTRY org.eclipse.jface 4 0 2014-08-22 00:29:56.752
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> What should I do? :(
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1410995 is a reply to message #1410953] |
Fri, 22 August 2014 06:13   |
On 22.08.14 05:15, Yongshin Kim wrote:
> Oh, thanks, I installed Mylyn. and It works now :)
> I think unother error comes from missing emf tool, I'll try to install
> that as well.
> But is there anything I can do to deal with "Could not resolve module:>
> org.eclipse.fx.ide.java6" error?
> You told me that it is normal if I use JDK6 or 7, but I think mine uses
> Oracle java8 which I confirmed with 'java -version'.
It's the opposite. If you run on java8 the bundle does not resolve, if
you would run on jdk6/7 it would resolve and bring up a message box
telling you that e(fx)clipse is disabled because it requires java8.
Tom
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411223 is a reply to message #1411196] |
Fri, 22 August 2014 18:24   |
Not really - we could in future make it a single feature so that you can
uninstall it easily.
Tom
On 22.08.14 18:33, Yongshin Kim wrote:
> Thomas Schindl wrote on Fri, 22 August 2014 02:13
>> On 22.08.14 05:15, It's the opposite. If you run on java8 the bundle
>> Tom
> I see. So I'm good :)
> But is there a way to suppress that warning? It is kinda annoying to see
> the error msg everytime I start the e(fx)clipse.
> Yongshin
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411381 is a reply to message #1411223] |
Sat, 23 August 2014 06:04   |
Thomas Schindl wrote on Fri, 22 August 2014 14:24Not really - we could in future make it a single feature so that you can
Tom
OK. I'll be patient and look forward for the new revision.
And one last question (Hope so )
What module should I install to deal with
"platform:/plugin/org.eclipse.e4.tools.emf.ui/fragment.e4xmi" thing?
Seid umschlungen Millionen! Diesen Kuss der ganzen Welt! -Beethoven-
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411412 is a reply to message #1411381] |
Sat, 23 August 2014 08:10   |
the e4 tooling should already be installed with the all-in-one package.
Tom
>> Tom
> And one last question (Hope so :d)
> Thanks :)
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1411494 is a reply to message #1411412] |
Sat, 23 August 2014 13:50   |
Thomas Schindl wrote on Sat, 23 August 2014 04:10the e4 tooling should already be installed with the all-in-one package.
Tom
!MESSAGE Nothing to merge for "platform:/plugin/org.eclipse.e4.tools.emf.ui/fragment.e4xmi"
I do indeed located fragment.e4xmi at "org.eclipse.e4.tools.emf.ui_0.12.0.v20140728-1808.jar" file at the plug-ins folder.
It has a lot of elements nodes in it. Should I test all the elements nodes by manually erasing them one by one and see what is causing the error msg?
Yongshin
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1419852 is a reply to message #1410995] |
Tue, 09 September 2014 07:14   |
Thomas Schindl wrote on Fri, 22 August 2014 02:13On 22.08.14 05:15, Yongshin Kim wrote:
> that as well.
Tom
May I suggest (IF POSSIBLE) changing the message and type into something less alarming then? Like a "You're properly using Java 8" warning.
From an user PoV if any other error happens and you just see "FrameworkEvent ERROR" you might think it could be one of the reasons and would spend some time checking it.
And great job, btw.
Re: I have installed the most recent e(fx)clipse AinO packages and it gives me this errors [message #1419857 is a reply to message #1419852] |
Tue, 09 September 2014 07:18   |
>> > that as well.
>> module:>
>> Tom
> And great job, btw.
I can not change this message it's from the Equinox-Resolver, we could
change to resolve always and do the checks once we are loaded. File a
bug and we'll try to look into this.
Tom
FUDForum. Page generated in 0.06270 seconds
