Using InstanceSpecification elements in SysML bdd [message #1410571] |
Thu, 21 August 2014 05:24 |
Tomas Sandkvist Messages: 149 Registered: October 2013 |
According to my "bible" on SysML, I should be able to create associations between instances:
"Instance specifications can be connected by links, which represent instances of associations between blocks. A link is shown on a block definition diagram as a line between two instance specifications, whose ends and adornments are the same as those of the association of which it is an instance.
Friedenthal, Sanford; Moore, Alan; Steiner, Rick (2011-11-22). A Practical Guide to SysML: The Systems Modeling Language (The MK/OMG Press) (Kindle Locations 4369-4371). Elsevier Science. Kindle Edition. "
Can't seem to make that work in Papyrus, is that a function not implemented or might I be doing this wrong? I just try to click and connect the instances as I would do with blocks, but all I get is a stop sign when hovering over an instance.
Tomas Sandkvist
FUDForum. Page generated in 0.02993 seconds
