Home » Eclipse Projects » Hudson » Hudson 3.2.0 Final is now available
Hudson 3.2.0 Final is now available [message #1410098] Tue, 19 August 2014 20:46 Go to next message
Greg Stachnick is currently offline Greg StachnickFriend
Hudson 3.2.0 is now available for production use from the downloads page. This milestone encapsulates the upgrade of the Spring libraries to Spring 3 and upgrades the capabilities of the Team support to full multi-tenancy with Job Group View and Slave isolation.
More details of the Hudson 3.2.0 work can be found on the Hudson Blog.
[Updated on: Tue, 19 August 2014 20:46]
Report message to a moderator
Re: Hudson 3.2.0 Final is now available [message #1413373 is a reply to message #1410098] Thu, 28 August 2014 11:20 Go to previous messageGo to next message
Oliver Pereira is currently offline Oliver PereiraFriend
The Active Directory plugin is broken.
It expects the Hudson version to be 3.2.0-M0.
Oli
Re: Hudson 3.2.0 Final is now available [message #1413552 is a reply to message #1413373] Thu, 28 August 2014 20:46 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
Probably Hudson version resolver is considering 3.2.0-M0 as a later version than 3.2.0. Need to re-release the plugin setting parent version to 3.2.0
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.2.0 Final is now available [message #1413612 is a reply to message #1410098] Fri, 29 August 2014 01:20 Go to previous messageGo to next message
Gerry Deng is currently offline Gerry DengFriend
Does anyone have workaround for this issue?
Re: Hudson 3.2.0 Final is now available [message #1413906 is a reply to message #1413612] Fri, 29 August 2014 18:34 Go to previous messageGo to next message
Can you please give more details.
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.2.0 Final is now available [message #1413908 is a reply to message #1413906] Fri, 29 August 2014 18:39 Go to previous messageGo to next message
Winston Prakash wrote on Fri, 29 August 2014 14:34
I think he has the same issue as me.
Re: Hudson 3.2.0 Final is now available [message #1413913 is a reply to message #1413908] Fri, 29 August 2014 18:46 Go to previous messageGo to next message
Oliver, is it only Hudson incorrectly mark in the Plugin Center or actually the plugin itself is broken. I thought the plugin itself loads and works fine. It is just that the Plugin Center incorrectly mark it.
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.2.0 Final is now available [message #1413930 is a reply to message #1413913] Fri, 29 August 2014 19:59 Go to previous messageGo to next message
Winston Prakash wrote on Fri, 29 August 2014 14:46
The plugin is marked with a yellow icon instead of a green one along with a warning message.
When I try to login it using my AD credentials it doesn't allow me to and the "remember me" checkbox is also missing.
Re: Hudson 3.2.0 Final is now available [message #1414691 is a reply to message #1413906] Mon, 01 September 2014 04:36 Go to previous messageGo to next message
1.I upgrade hudson from 3.1.2 to 3.2.0
2.Check all the plugins. the active directory is enabled(expected).
3.Configure security:there is no active directory option(unexpected).
Re: Hudson 3.2.0 Final is now available [message #1415469 is a reply to message #1414691] Tue, 02 September 2014 21:32 Go to previous messageGo to next message
Any exception in Hudson log?
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.2.0 Final is now available [message #1415595 is a reply to message #1415469] Wed, 03 September 2014 06:28 Go to previous messageGo to next message
Winston Prakash wrote on Tue, 02 September 2014 17:32
No exception.
Re: Hudson 3.2.0 Final is now available [message #1415804 is a reply to message #1410098] Wed, 03 September 2014 17:15 Go to previous messageGo to next message
Geoff Waymark is currently offline Geoff WaymarkFriend
The active directory issue was a problem caused from our side.
Hudson 3.2.0 required a new version of the active directory plugin (1.31-h2) however the Hudson version this was released against was 3.2.0-M0 not 3.2.0. This causes the upgrade logic to not trigger for the active directory plugin as it should and you are therefore stuck on the incompatible 1.31-h1.
Downloading the 1.31-h2 active directory plugin hpi [http://hudson-ci.org/update-center3.2/downloads/plugins/active-directory/1.31-h2/active-directory.hpi] and installing it manually should fix this. Winston is going to re-release the active directory plugin with a corrected version today so nobody else has this issue.
Thanks for helping us chase it down.
Geoff Waymark
Eclipse Hudson team
Re: Hudson 3.2.0 Final is now available [message #1415840 is a reply to message #1415804] Wed, 03 September 2014 19:56 Go to previous messageGo to next message
I uploaded the active-directory plugin version 1.31-h3. Try to update the plugin and see if Active Directory entry shows up in the security panel.
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.2.0 Final is now available [message #1417302 is a reply to message #1415804] Fri, 05 September 2014 06:02 Go to previous messageGo to next message
Geoff Waymark wrote on Wed, 03 September 2014 13:15
I tried 1.31-h2 and 1.31-h3, still can't see the active directory option.
Re: Hudson 3.2.0 Final is now available [message #1417306 is a reply to message #1417302] Fri, 05 September 2014 06:18 Go to previous message
Gerry Deng wrote on Fri, 05 September 2014 02:02
I removed the active directory plugin in .hudson/plugins directory and install it again, I got the active directory option. Thanks.
Previous Topic:Hudson Migration Steps from 2.2.0 to 3.0.1 on windows2008 server
Next Topic:Hudson Clearcase plugin not showing up
Current Time: Mon Oct 26 11:05:42 GMT 2020
Powered by FUDForum. Page generated in 0.02905 seconds
