Jubula not saving my testreports [message #1410019] |
Tue, 19 August 2014 11:24  |
So I have this testSuite to test one installer, and when the testSuite ends I can see Tue Aug 19 10:06:39 CDT 2014 End of Test Suite
Tue Aug 19 10:06:39 CDT 2014 Writing Report to Database
Tue Aug 19 10:06:40 CDT 2014 AUT: Disconnected.
Tue Aug 19 10:06:40 CDT 2014 AUT Agent: connection closed.
However, it does not writes the .htm and .xml report files, and in the database the
"details" collumm is set to false.
How can I keep jubula from "deleting"/"not saving" the details of a run?
I'm running the testSuite using testexec
with the following commands:
./testexec -project ___Installer -version 1.0 -testsuite PerformFreshTypicalInstallation_L -server localhost -port 60000 -autconfig ___Installer@localhost -datadir /home/fbgomes/workspace2 -resultdir /home/fbgomes/workspace2/result -data /home/fbgomes/workspace2 -language en_US -dbuser sa -dbpw "" -dburl "jdbc:h2:../jubuladb/database;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE"
Edit: I'm still trying to find out why this happens, but looks like it only happens with one my projects( it works normally with the others)
Thanks in Advance
[Updated on: Tue, 19 August 2014 12:01] by Moderator
Re: Jubula not saving my testreports [message #1750142 is a reply to message #1410019] |
Fri, 16 December 2016 06:01  |
Hi Dinh,
as far as I understand your problem now, this is already fixed in the upcoming Jubula 8.4.0 release, which will be released somewhen during the next weeks. After the release, please upgrade to 8.4.0 and check if this problem still exists.
Kevin
FUDForum. Page generated in 0.05665 seconds
