Re: the right way to deal with requests [message #248857 is a reply to message #248842] |
Fri, 08 May 2009 00:11 |
Originally posted by: alamothe.ptt.yu
AbstractTool tool = (AbstractTool) editDomain.getActiveTool();
Method m = AbstractTool.class.getDeclaredMethod("getLocation");
m.setAccessible(true);
location = (Point) m.invoke(tool);
You also need to traslate the point, take a look at
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy on how to do this
Ben Vitale wrote:
> The entry is not suggesting that you can't create new parts using the
> context menu.
> It seems like good advice to me that you shouldn't rely on a location
> that may not work in all scenarios.
> If you have a snippet to get the context menu location, please post
> it.
> Thanks
> Ben
> Nikola Mihajlovic wrote:
>> That doesn't help at all, the author of the FAQ was just being a
>> smartass. They should have explained how to find the location of the
>> context menu if it was brought via mouse. I'm sure that GMF creates
>> parts via the context menu, so what is the problem?
>> Ben Vitale wrote:
>>> Regarding the location of the context menu,
>>> http://wiki.eclipse.org/index.php/GEF_Developer_FAQ#How_do_I _find_the_location_of_the_context_menu.3F
>>> -Ben
>>> Ren
Re: the right way to deal with requests [message #248988 is a reply to message #248857] |
Fri, 15 May 2009 10:03 |
René Messages: 45 Registered: July 2009 |
Member |
hey folks,
thanks for your many many replies. unfortunately i was very busy the
last 2 weeks, so that i have today the first chance to look at your posts.
you have post a lot to determine the location where the actions is
performed. thanks for that. maybe you can give me a short overview how
to deal with request? that would very useful.
thanks again and regards,
rené
>> context menu.
>> it.
>> Thanks
>> Ben
>>>> -Ben
>>>> René wrote:
>>>>> hi folks,
>>>>> i want to create components in my diagram via the context menu of
>>>>> my editor. therefore i added a action that create a CreateRequest
>>>>> and a CreationFactory. The next step was that i called the
>>>>> performRequest-method of my responsible editpart. but the default
>>>>> implementation of this method is empty and i have to implement the
>>>>> method myself. but i m in doubt how i do this. can you please give
>>>>> me some hints what are the next steps? is it possible to determine
>>>>> the position where the context menu was opened?
Re: the right way to deal with requests [message #248993 is a reply to message #248988] |
Fri, 15 May 2009 15:49 |
Member |
hey,
its me again. i solved the problem with the request. it was much easier
than i thought. you have to call just getCommand(Request) of the
responsible edit part. this uses the registered edit policies to create
and return the correct command...
i just want to thank you again. specially nikolas post was very helpful
and works immediately. the use of reflection to get the drop location is
a nice hack and i properly have to pondering for years to come to this
idea. btw: i didn't have to translate the location. it was out of the
box relative to my diagram domain.
best regards,
rené
René wrote:
> hey folks,
> rené
>> this
>>> context menu.
>>> it.
>>> Thanks
>>> Ben
>>>>> -Ben
>>>>> René wrote:
>>>>>> hi folks,
FUDForum. Page generated in 0.03287 seconds
