Home » Eclipse Projects » GEF » negative coordinates
negative coordinates [message #248695] Mon, 27 April 2009 09:25 Go to next message
I
Re: negative coordinates [message #248703 is a reply to message #248695] Mon, 27 April 2009 13:31 Go to previous messageGo to next message
Originally posted by: cayla_sha.gmx.net
You could catch the event (the event that user moved element) and then
correct the coordinates, if they`re smaller than 0, like setting them to
0 or 1.
Carsten Spieker schrieb:
> IŽm still quite new to GEF editors.
> Is there any possibility to keep the user from creating an element in the
> negative coordinate area of the editor?
> Thanks and Greetz,
> Carsten
Re: negative coordinates [message #248713 is a reply to message #248703] Tue, 28 April 2009 02:24 Go to previous messageGo to next message
thanks for that hint.
Now I have changed the edit policy which is checked when moving a child and
manipulate the target rectangle if x or y are <0.
Greetz,
Carsten
"Cayla Sha" <cayla_sha@gmx.net> schrieb im Newsbeitrag
news:gt4q4g$ptb$1@build.eclipse.org...
> correct the coordinates, if they`re smaller than 0, like setting them to 0
> or 1.
>> Hi,
>> I
Re: negative coordinates [message #248753 is a reply to message #248695] Wed, 29 April 2009 12:45 Go to previous message
If I understand your question correctly, you might want to use a root
edit part that is not free form.
That is, use ScalableRootEditPart instead of ScalableFreeformRootEditPart.
Ben
Carsten Spieker wrote:
> I´m still quite new to GEF editors.
> Thanks and Greetz,
> Carsten
Previous Topic:Node and Connection creation inconsistency?
Next Topic:probem with connection anchors when zoomed
Current Time: Thu Apr 24 10:38:57 EDT 2025
Powered by FUDForum. Page generated in 0.03193 seconds
